cgal-discuss - convex hull for points
  • To:
  • Subject: convex hull for points
  • Date: Tue, 18 Mar 2008 17:54:24 +0800 (CST)
hi, all.
I want to get the convex hull of a set of points. The number of the Points is about 10K. My code is like below:
typedef CGAL::Cartesian<double> K;
typedef K::Point_3 Point_3;
typedef CGAL::Polyhedron_3< K> Polyhedron;
Polyhedron P; // define polyhedron to hold convex hull
convex_hull_incremental_3( pset.begin(), pset.end(), P);
It is compiled ok, but when run the programe it abort and output message like:
CGAL::Polyhedron_incremental_builder_3<HDS>::
lookup_halfedge(): input error: facet 1857 shares a halfedge from vertex 942 to vertex 881 with facet 1738.
CGAL error: assertion violation!
Expr: check_protocoll == 0
File: /usr/include/CGAL/Polyhedron_incremental_builder_3.h
Line: 198
Explanation:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Line: 198
Aborted
When I reduced the number of points to 4k, I get the right result. I can't understand why it happen. Is there something wrong with the Kernel?
Thank you for your attention!
快来和我一起享受TOM免费邮箱吧! 看看除了1.5G,还有什么?
看看女人都在聊什么? 美图尽赏 聊天世界
明星金曲免费送(http://mm.tom.com/ivr/):周杰伦 林俊杰 庞龙 张惠妹
劲爆歌曲尽情点(http://mm.tom.com/ivr/):霍元甲 吉祥三宝 人质 曹操
炫酷彩铃免费送(http://mm.tom.com/cailing/):周杰伦帮你接电话 麻烦女朋友 七里香 小城故事
