- To:
- Subject: Re: [cgal-discuss] Triangulation 2 data structure problem
- Date: Wed, 26 Mar 2008 10:02:21 +0100
The most important information here might be the fact that "the set of maintained faces is topologically equivalent to a two-dimensional triangulated sphere." See the user manual (Section 1 - definition, in particular 26.1.2 The Set of Faces and Vertices, that also mentions the lower dimensional cases).
best
Monique Teillaud
Louis wrote:
Thanks for the information Pedro. Initially I didn't set the
neighborhood information because I don't know what are done
automatically in by the data structure itself or what the user has to
specify. When I insert a vertex or face, calling vertex.is_valid() or
face.is_valid() all returned true. But the triangulation data
structure remained invalid. Now after I set the neighborhood
information, the triangulation still says it's invalid. I'm also not
sure about boundary faces where 1 or 2 neighbor faces are not defined,
do I need to do anything special in this case?
What's frustrating is the lack of information in the documentation on
what are the necessary steps to build a valid triangulation using this
data structure. There are many weird behaviors in this data structure
that need answers. Why does the class initialize with 0 vertices, 1
face, 1 edge? Calling tds.clear() made sure they became 0, but when
you add the first vertex, somehow it's not counted
(number_of_vertices() returns 0).
I wonder if anyone has a concrete example or maybe skeleton code that
shows how to build a triangulation data structure from vertices and
faces.
Thanks,
Louis
On Tue, Mar 25, 2008 at 7:27 AM, Pedro Machado Manhães de Castro
wrote:
I meant stuffs like:
fHandle->set_neighbor(0, some_face_handle_1);
fHandle->set_neighbor(1, some_face_handle_2);
fHandle->set_neighbor(2, some_face_handle_3);
sry (to not confuse even more),
Pedro
On Tue, Mar 25, 2008 at 3:25 PM, Pedro Machado Manhães de Castro
wrote:
Hello,
Do you define the neighborhood of your face inside your 2nd for iteration?
Stuffs like:
fHandle->set_neighbor(0, some_face_handle_2);
fHandle->set_neighbor(0, some_face_handle_3);
inside
This constructor here is easier to use:
create_face(Face_handle f1, int i1,
Face_handle f2, int i2,
Face_handle f3, int i3)
You define a face by its 3 neighbors, i1, i2, i3 are any sequence defined
by the indices 0, 1, 2.
Hope it could help,
Best Regard,
Pedro Machado
On Tue, Mar 25, 2008 at 11:43 AM, Louis Feng
wrote:
Hello,
I'm trying to construct a 2D triangle mesh from a list of vertices and
faces. I didn't want to use Polyhedron because I needed some properties
from
the 2D triangulation class. I'm using Triangulation_2 and
Triangulation_data_structure_2. Basically I use T.tds() to get a
reference
to the internal data structure. Then I add vertices and faces to it. But
this has become very confusing and I couldn't find examples on this.
An outline of my code:
triDS.set_dimension(2);
for(...) {
VertexHandle vHandle = triDS.create_vertex();
vHandle->set_point(Point2(...));
for(...) {
FaceHandle fHandle = triDS.create_face(vHandle1, vHandle2, vHandle3); }
When I check triDS.is_valid() at the end, it returns false. More
interestingly, before I add anything to triDS, when I check the
vertices,
edge, etc. I get this
Triangulation vertices: 0
Triangulation faces: 1
Triangulation full faces: 1
Triangulation edges: 1
So am I suppose to clear this before I add something to it? Looking at
the
template file for the data structure, it check this:
case 2:
result = result && edge_count == 3*face_count/2 ;
CGAL_triangulation_assertion(edge_count == 3*face_count/2);
break;
I'm not sure what the expected behavior is. Could someone tell me what
I'm
doing wrong and how this class suppose to be used? Thanks!
Louis
- Triangulation 2 data structure problem, Louis Feng, 03/25/2008
- Re: [cgal-discuss] Triangulation 2 data structure problem, Pedro Machado Manhães de Castro, 03/25/2008
- Re: [cgal-discuss] Triangulation 2 data structure problem, Louis, 03/25/2008
- Re: [cgal-discuss] Triangulation 2 data structure problem, Monique . Teillaud, 03/26/2008
- Re: [cgal-discuss] Triangulation 2 data structure problem, Pedro Machado Manhães de Castro, 03/26/2008
- RE: [cgal-discuss] Triangulation 2 data structure problem, Louis Feng, 03/30/2008
