cgal-discuss - Delaunay_triangulation_2
  • To:
  • Subject: Delaunay_triangulation_2
  • Date: Sat, 29 Mar 2008 22:27:38 +0100
Hi all,
I am in the process of migrating some Delaunay triangulation/voronoi diagram
code to use the CGAL implementation. The code uses properties of the delaunay
triangulation and voronoi diagram in order to produce a variety of metrics
from output from a forest fire simulation. Many of these simulations result
extremely large numbers of vertices's, which is where we are running into
problems.
When built in debug mode, our CGAL backed implementation works correctly,
however when the project is built in release mode, its a whole other story.
There are two commonly encountered errors, so far we have have not been able
to determine the reason, or even the circumstances under which, these errors
occur. In all cases the error occurs as a result of calling the insert(Point)
method on the triangulation.
Everything is being compiled in Visual Studio 2008.
Rather than posting code from our implementation, I will present two very
simple loops that seem to trigger the errors. If anybody can help explain
what is going wrong, or make suggestions as to how to fix it, I would be very
grateful!
I have been scratching my head with this one for a while now and am running
low on ideas.
The following includes and typedef's are in the header:
> #include <CGAL/basic.h>
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/Delaunay_triangulation_2.h>
> struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
> typedef CGAL::Delaunay_triangulation_2<K>
> Triangulation;
> typedef Triangulation::Point
> Point;
The follow loop causes an error to be thrown in dblhook.c.
> Triangulation T;
> for (long i=1; i<15000; i++) {
> T.insert(Point(1.0f/i, i%3));
And, oddly enough, the minor change below changes the error dramatically, in
particular it now throws a std::length_error exception in "iosfwd",
specifically in "std::_Traits_helper::length_error()"
> Triangulation T;
> T.insert(Point(1.0f/i, rand()%100));
And, even weirder, the following modification gets rid of the error
altogether.
> Triangulation T;
> T.insert(Point(1.0f/i, i%100));
Note that the results change if we change the number of points added. For a
sufficiently small set of vertices's, it seems to work every time. As the
number increases, the likelihood of one of these errors occurring increases
correspondingly.
Any insight into the source of these problems would be immensely helpful.
-Ryan
