- To:
- Subject: Re: [cgal-discuss] Triangulation issue - bug?
- Date: Mon, 31 Mar 2008 12:54:49 +0200
- Organization: INRIA
a écrit :
Hello, with new version 3.3.1 we started to have issue with Triangulation_3 class. As I found out, interface of Triangle_3 was rewritten, however interface of TriangleC3 (cartesian one) remained same, so it's not possible to construct triangulation with cartesian base. Construct_triangle_3 class in function_objects.h has it's interface rewritten, so "typedef typename Triangle_3::Rep Rep" gives "cannot access private typedef declared in class 'CGAL::TriangleC3<R_>". Is this CGAL 3.3.1 bug?
Maybe, but I do not understand your message enough.
Could you post code snippets or compiler error messages
that illustrate the problem?
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
smime.p7s
Description: S/MIME Cryptographic Signature
- Triangulation issue - bug?, petr . dannhofer, 03/31/2008
- Re: [cgal-discuss] Triangulation issue - bug?, Sylvain Pion, 03/31/2008
