cgal-discuss - Re: [cgal-discuss] path optimization
  • To:
  • Subject: Re: [cgal-discuss] path optimization
  • Date: Mon, 07 Apr 2008 14:28:29 +0200
Andy Hirsh wrote:
for an optimization algorithm I would like to know if there is a way
to evaluate the minimum path along some (eg 1000) vectors using
CGAL... all vectors need to be traversed only once, I can
change the directions of vectors and I can also add some "jump
vectors" if needed...
It seems that you are talking about a variant of the traveling salesperson problem (TSP) which is notoriously difficult even for small inputs, and in two dimensions. As a CGAL editor, I'm flattered that you consider CGAL a possible source of solutions, but I'm afraid that this is beyond the scope of CGAL. I throught a little bit about whether the flexibility of changing vector orientations makes the problem easy in some miraculous way, but I could not think of anything.
There are reasonable heuristics for TSP, some of them even with approximation guarantees (see for example http://en.wikipedia.org/wiki/Traveling_salesman_problem); you might want to try some of them, and then CGAL might come handy to do certain basic computations.
Best,
Bernd.
