Re: [cgal-discuss] Re: Nef_polyhedron: cannot convert to an enriched polyhedron
- To:
- Subject: Re: [cgal-discuss] Re: Nef_polyhedron: cannot convert to an enriched polyhedron
- Date: Tue, 08 Apr 2008 11:56:36 +0200
Hi Mengda,
Nef polyhedra are represented uniquely, i.e., If you have coplanar
triangles then they are united to a single facet. We thought of this as
a feature, but sometime people don't like it. Also if we output the
results with floating-point coordinates, facets with more than three
vertices often are not coplanar any more with these coordinates. So I
changed the output in such a way that facets with more than three
vertices are triangulated in the conversion to Polyhedron_3. If you
don't like it, I can tell you how to turn it off. I should offer this as
a regular option in the next release.
Peter
On Mon, 2008-04-07 at 17:36 -0700, Mengda Wu wrote:
> Hi Peter,
> Thanks a lot! It works for me this way.
> I have a question of the result. I had two closed polyhedra. One is
> a complex shape (mesh1.off) and the other is a cylinder (mesh2.off).
> Please see
> the attached image (unionbefore.png) for them.
> I unioned them together using the code like this:
> Polyhedron mesh1;
> Polyhedron mesh2;
> //load mesh1 and mesh2 here
> Nef_Polyhedron model1(mesh1);
> Nef_Polyhedron model2(mesh2);
> model1 = model1 + model2;
> if( model1.is_simple() )
> model1.convert_to_Polyhedron(mesh1);
> I got the result shown in the attached image (unionafter.png). The
> union operation is successful
> but the triangles on one of the face of the cylinder (pointed by a
> white arrow in the image) are all changed
> to weird shapes. I thought the union operation should not affect the
> triangles there.
> I am wondering why this happened. Is it possible to keep the
> triangles there intact?
> Thanks,
> Mengda
> 2008/4/7, Peter Hachenberger
> Hi Mengda,
> you are right. In convert_to_Polyhedron the type of
> Polyhedron is hard wired to Polyhedron_3<Kernel>, which
> does not allow different items. That surely is more
> restrictive than I
> want it to be. Please try to overwrite the function in your
> file
> Nef_polyhedron_3.h by
> template<typename Polyhedron>
> void convert_to_Polyhedron(Polyhedron& P) {
> typedef typename Polyhedron::HalfedgeDS HalfedgeDS;
> CGAL_precondition(is_simple());
> P.clear();
> Build_polyhedron<HalfedgeDS> bp(*this);
> P.delegate(bp);
> Please tell me whether it worked.
> Peter
> On Mon, 2008-04-07 at 00:47 -0700, Mengda Wu wrote:
> > Sorry. I forgot to attach last time. Here it is.
> > Thanks,
> > Mengda
> > ---------- Forwarded message ----------
> > From: Mengda Wu
> > Date: 2008-4-7 0:43
> > Subject: Nef_polyhedron: cannot convert to an enriched
> polyhedron
> > To:
> > Hi Peter,
> > Thanks a lot for your explanations. I am testing the
> results.
> > But I have an side problem because of which I cannot try
> the union
> > operation.
> > I am using an enriched polyhedron, which enriches the
> contents of
> > vertices,
> > halfedges, and facets in the polyhedron (see attach). But I
> cannot
> > compile when
> > I try to use convert_to_Polyhedron function.
> > error C2664:
> > 'CGAL::Nef_polyhedron_3<Kernel_>::convert_to_Polyhedron' :
> cannot
> > convert parameter 1 from
> 'MyCGALprogram::Enriched_Polyhedron' to
> > 'CGAL::Polyhedron_3<PolyhedronTraits_3> &
> > It seems that the Nef_polyhedron_3
> > has been hardcoded to use the CGAL::Polyhedron_3. Is there a
> way to
> > get around of this?
> > Thanks,
> > Mengda
> > 2008/4/5, Peter Hachenberger
> > Hi Mengda,
> > in the latest CGAL version the Nef polyhedra are
> getting
> > triangulated if
> > you convert them to polyhedral surfaces. If you want
> that
> > conversion
> > anyway to put the resulting polyhedron out as an off
> file in
> > the end,
> > then there should only be one problem. Not every Nef
> > polyhedron can be
> > converted to a polyhedral surface. Look into the
> user manual
> > for details
> > on that.
> > Peter
> > On Sat, 2008-04-05 at 14:59 -0700, Mengda Wu wrote:
> > > Hi there,
> > > I have two polyhedra which are triangular,
> manifold, and
> > have one
> > > overlap region. I am wondering whether
> > > I can get a polyhedron which is union of the two,
> also
> > triangular and
> > > manifold through Nef_polyhedron union operation.
> > > How can I ensure the faces near the joint are
> triangular?
> > > Thanks,
> > > Mengda
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
- Nef_polyhedron: cannot convert to an enriched polyhedron, Mengda Wu, 04/07/2008
- Message not available
- Re: Nef_polyhedron: cannot convert to an enriched polyhedron, Mengda Wu, 04/08/2008
- Re: [cgal-discuss] Re: Nef_polyhedron: cannot convert to an enriched polyhedron, Peter Hachenberger, 04/08/2008
- Re: [cgal-discuss] Re: Nef_polyhedron: cannot convert to an enriched polyhedron, Mengda Wu, 04/08/2008
