- To:
- Subject: Re: [cgal-discuss] How to find coordinates of Segment Voronoi Vertex
- Date: Tue, 8 Apr 2008 16:39:44 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=WwRkbERcXMGRyksv9OyzvGDZoXLmLx5qWhDU7jP/D8OXorEcN9ZZi37v1hvL9bRGMMLJWYhTtIi6LzKUCwoKt+t46+RxHDsaq3VGGbX7Aki7MCAnEDTqp4+GUM7hQKfBb8QHFJWHOl/QKkwSST9cjzM2HHimwkrdXyAKSvQubtk=
Hi,
Thanks Daniel and Andreas for the valuable inputs.....Daniel's method works if the sites are points..........finally I could get the coordinates using Voronoi Adapter.
Serge,
sdg.dual() thing works for Delaunay_triangulation_2. It does not work for Segment_Delaunay_graph_2.
What you need to do is to go for the 'Voronoi Adapter'.
Read this chapter http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Voronoi_diagram_2/Chapter_main.html and also the corresponding manual.
Thus define a Voronoi_diagram_2 and Segment_Delaunay_graph_2 both.
Generate the Voronoi diagram first and get its dual by sdg = vd.dual();
You can then get all the voronoi vertices using Vertex_iterator, using for loop like for(vit = vd.vertices_begin(); vit != vd.vertices_end(); ++vit)
Please let me know if you have any problem.
Thanks & Regards,
Amit Pendharkar
On Tue, Apr 8, 2008 at 3:05 AM, Serge Rehbinder <> wrote:
Hi,
I also want to get the vertices Cartesian coordinates , I'm trying to put into pratice what M Duque wrote but when I write :
CGAL::Object o = sdg.dual(eit2);
There's a compilation error :
error C2039: 'dual' : n'est pas membre de 'CGAL::Sdg2<Gt>'
which means 'dual' isn't member of 'CGAL::Sdg2<Gt>'
Can someone help me ?
Serge2008/4/4, Andreas Fabri <>:
Hello,
note that CGAL offers an adapter for the Segment Delaunay graph
http://www.cgal.org/Pkg/VoronoiDiagramAdaptor2
andreas
Amit Pendharkar wrote:
Hi All,
I am using Segment Voronoi algorithm(Segment Delaunay Graph) to find the Voronoi edges.
I want to find out the 'voronoi vertices' i.e. those points where two or more voronoi edges meet.
I referred to the program /CGAL/examples/Segment_Delaunay_graph_2/sdg-voronoi-edges.cpp
It gives the edges according to \ /
\ B /
C ----------------- D
/ A \
i.e. it gives A, B, C & D.
My question is - how can I get the coordinates of the voronoi vertex formed due to ABC or BAD ?????? I want the cartesian x, y coordinates of those vertices.
This is kind of urgent. Can anybody please comment on this. All the inputs are highly appreciated.
Thanks & Regards,
Amit Pendharkar
- How to find coordinates of Segment Voronoi Vertex, Amit Pendharkar, 04/04/2008
- Re: [cgal-discuss] How to find coordinates of Segment Voronoi Vertex, Daniel Duque Campayo, 04/04/2008
- Re: [cgal-discuss] How to find coordinates of Segment Voronoi Vertex, Andreas Fabri, 04/04/2008
- Re: [cgal-discuss] How to find coordinates of Segment Voronoi Vertex, Serge Rehbinder, 04/08/2008
- Re: [cgal-discuss] How to find coordinates of Segment Voronoi Vertex, Amit Pendharkar, 04/08/2008
