- To: CGAL Discussion list <>
- Subject: 3D Delaunay/Voronoi performance
- Date: Wed, 9 Apr 2008 12:40:58 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:from:to:content-type:content-transfer-encoding:mime-version:subject:date:x-mailer; b=R0CZZOOiZ9QvzhHstx4HFR1+/R4Tm8nw+0ox6d1sLQZOXdnM0Ihzb+edON6Oqsif/mzMeS1SEv05U74RiWck5l2JZRiDTKSseLfyMDZ5dQnix0Txcz+F/5lkfjMvEX+9VkfFhjEpyXHdypVtMDnWeGR9KSUK+7IquEK7QP6ewYc=
I am trying to use Delaunay_Triangulation_3 to calculate the Delaunay triangulation and Voronoi diagram of a set of moving points in 3D. My algorithm therefore makes heavy use of DT3::move_point. I have found that while performance is acceptable using a kernel with inexact constructions, once I switch to exact constructions to guarantee the Voronoi diagram performance degrades badly.
More specifically, DT3::remove (which is called by move_point) seems to allocate vast quantities of memory evaluating expressions involving GMP objects. This quickly fills up my physical memory, leading to thrashing as the OS tries to swap pages out to disk. This happens when there are only about 30 vertices in the triangulation.
I have two questions:
1. Is DT3::move_point a good way to deal with many moving points? In the long run, I intend to implement the algorithm of Schaller & Meyer- Hermann (2004), but I had thought that the simple remove & re-insert strategy would be adequate for small numbers of cells.
2. How important is it to use exact constructions when using the DT3::dual functions? Will inexact constructions lead to highly inaccurate results, or are they acceptable when double precision floating point results are sufficient?
Thanks,
Jeremy
Reference:
Schaller, G. and Meyer-Hermann, M. (2004). Kinetic and dynamic Delaunay tetrahedralizations in three dimensions, Computer Physics Communications, 162(1), 9-23. doi:10.1016/j.cpc.2004.06.066
PS. Some context: I am using CGAL::Delaunay_Triangulation_3 in an agent-based model of skin cells as part of my PhD project.
The forceps of our minds are clumsy forceps, and crush the truth a little in taking hold of it. - H. G. Wells
Jeremy Cope
Ph.D. Student, Computational Systems Biology
Department of Computer Science, University of Sheffield
- 3D Delaunay/Voronoi performance, Jeremy Cope, 04/09/2008
- Re: [cgal-discuss] 3D Delaunay/Voronoi performance, Camille . Wormser, 04/09/2008
