cgal-discuss - Re: [cgal-discuss] Nef_Polyhedron & list iterators incompatible
  • To:
  • Subject: Re: [cgal-discuss] Nef_Polyhedron & list iterators incompatible
  • Date: Mon, 14 Apr 2008 19:46:16 +0200
Thank you for a fast answer Andreas,
I've checked the macros with
#if _HAS_ITERATOR_DEBUGGING == 1
#error defined!!!
#endif
for CGAL (placing that snippet on top of kernel.cpp)
and also for example file transformation.cpp
result:
both _HAS_ITERATOR_DEBUGGING and _SECURE_SCL are defined in cgal.lib
and none of them is defined in transformation.vcproj
if I try defining them on top of transformation.cpp, I get the warning
1>C:\Program Files\Microsoft Visual Studio 8\VC\include\yvals.h(101) :
warning CRT1005: Iterator debugging not supported in retail builds.
1> Setting 1=0
the application breakes like before at _debugger_hook_dummy = 0;
in dbghook.c which is provided for you below.
I'm also wondering why _HAS_ITERATOR_DEBUGGING 1 is defined in cgal.lib,
because I could not find where _DEBUG was +defined.
#if !defined (_HAS_ITERATOR_DEBUGGING)
#if defined (_DEBUG)
#define _HAS_ITERATOR_DEBUGGING 1 /* for range checks,
etc. */
#else
#define _HAS_ITERATOR_DEBUGGING 0
#endif /* defined (_DEBUG) */
#else
*dbghook.c - Debug CRT Hook Functions
* Copyright (c) Microsoft Corporation. All rights reserved.
*Purpose:
* Allow users to override default alloc hook at link time.
#include <dbgint.h>
#ifdef _DEBUG
#include <internal.h>
#include <limits.h>
#include <mtdll.h>
#include <malloc.h>
#include <stdlib.h>
_CRT_ALLOC_HOOK _pfnAllocHook = _CrtDefaultAllocHook;
*int _CrtDefaultAllocHook() - allow allocation
*Purpose:
* allow allocation
*Entry:
* all parameters ignored
*Exit:
* returns TRUE
*Exceptions:
int __cdecl _CrtDefaultAllocHook(
int nAllocType,
void * pvData,
size_t nSize,
int nBlockUse,
long lRequest,
const unsigned char * szFileName,
int nLine
return 1; /* allow all allocs/reallocs/frees */
#endif /* _DEBUG */
int _debugger_hook_dummy;
#ifdef _M_IA64
#undef _CRT_DEBUGGER_HOOK
#define _CRT_DEBUGGER_HOOK __crt_debugger_hook
#endif /* _M_IA64 */
__declspec(noinline)
void __cdecl _CRT_DEBUGGER_HOOK(int _Reserved)
/* assign 0 to _debugger_hook_dummy so that the function is not folded in
retail */
(_Reserved);
-------- Original-Nachricht --------
> Datum: Mon, 14 Apr 2008 17:25:07 +0200
> Von: Andreas Fabri
> An:
> Betreff: Re: [cgal-discuss] Nef_Polyhedron & list iterators incompatible
> Anatoli Barski wrote:
> > Probably a better screenshot of the same callstack attached
> Can you check whether _HAS_ITERATOR_DEBUGING and _SECURE_SCL are defined
> consistently in cgal.lib and your application.
> andreas
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
