- To: CGAL discuss <>
- Subject: drawing a conic arc using Qt_widget
- Date: Sat, 19 Apr 2008 03:53:55 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=4bwGIFFudfm0Nbh/JmZyqUOKIMUw310fWkBM8ZVAvRO8RC1J2otQmrma9nvRbZtQ6437lm9eg6wO8tkVPpaJXtY5ORQymfcLHGxACx45AAlnvNiNV/M7NBh6UV+Gkfto532dVEPARLsN7ahmlBCWpTg9qxNu7qxa3Vj90dCvyC8=;
Hello,
It seems that QT widget can dra segments but not conic arcs. For example, the statement:
std::vector< Rat_point_2 > myPointsL;
*w << Rat_segment_2( myPointsL[i], myPointsL[i+1] );
has no error and in the output there is a segment. Now if I want to draw a conic arc:
Rat_circle_2 Circ2;
Conic_arc_2 con;
Point_2 s, e;
Conic_arc_2 con;
Point_2 s, e;
*w << Conic_arc_2 ( Circ2, CGAL::COUNTERCLOCKWISE, s, e );
At this line I get:
error C2678: binary '<<' : no operator found which takes a left-hand operand of type 'CGAL::Qt_widget' (or there is no acceptable conversion)
Am I right? How can I draw a conic arc from one point to another point (with a given center)?
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
- drawing a conic arc using Qt_widget, Mahmood Naderan, 04/19/2008
- Re: [cgal-discuss] drawing a conic arc using Qt_widget, Ashwin Nanjappa, 04/21/2008
