- To:
- Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
- Date: Fri, 25 Apr 2008 21:22:58 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=ei1qjhaBKytimwr/9NG1C4pgnFPbiwqrTSJMm+eghbujW0VhFt6SeDxeguqzBZ2GK4NBbMuETumy5J24vKN0KUuq9uCtdAw3wAAWQb/QFEDi0kyaOBk/U5SP4EvuzhhZvjL/4dlNX+UUKI3xuBnETiL02DiUVlRIr45sKfLv0V8=
Hello,
I encountered the same problem when trying to use boost program options with VC 9.0.
Compiling boost with VC 9.0, following these instructions http://www.quantnet.org/forum/showthread.php?t=2221&page=2
solved the problem.
Ophir
On Fri, Apr 25, 2008 at 8:06 AM, Ashwin Nanjappa <> wrote:
Wesley Smith wrote:If it helps, I'm using CGAL with VC++ Express Edition 2008 with no problems.
Hi,
Has anyone managed to get CGAL working on VS2008? I'm still having
linker problems with MP_Float.obj missing symbols. From what I've
found online, this potentially has something to do with mixed runtime
libs, but the only libs in my project are the ones CGAL built and gmp.
Could this be a Boost issue??? I really have no idea, but I would
like to hear if this is in fact possible and I can go from there.
~ash
- VS2008 link problems: ContainerBase, Wesley Smith, 04/24/2008
- Re: VS2008 link problems: ContainerBase, Wesley Smith, 04/25/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Ashwin Nanjappa, 04/25/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Ophir Setter, 04/25/2008
