- To:
- Subject: Re: [cgal-discuss] Intersection - voronoi and polygon
- Date: Tue, 29 Apr 2008 13:14:26 +0800
wrote:
@~ash
Thank you for the reply. Which is the right routine for computing the
intersection? This one:
CGAL::intersection ( Type1<Kernel> obj1, Type2<Kernel> obj2)
is just for the types: Line_2, Segment_2,...
Which routine can I use for the voronoi edges ?
See:
<http://www.cgal.org/Manual/3.3.1/doc_html/cgal_manual/Kernel_23_ref/Function_intersection.html>
You can intersect a Iso_rectangle_2 with a Segment_2. A Voronoi edge is a Segment_2. You could form a Iso_rectangle_2 around your polygon and intersect it with Segment_2 to get the intersection point. Then check if this point lies on the polygon by using its bounded_side() function.
~ash
- Re: Re: [cgal-discuss] Intersection - voronoi and polygon, neugebap, 04/28/2008
- Re: [cgal-discuss] Intersection - voronoi and polygon, Ashwin Nanjappa, 04/29/2008
- Re: [cgal-discuss] Intersection - voronoi and polygon, Paul Neugebauer, 04/29/2008
