- To:
- Subject: Re: [cgal-discuss] Re: Precondition_exception in Sign_Sturm_sequence.h
- Date: Tue, 29 Apr 2008 15:19:37 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:from:to:in-reply-to:content-type:content-transfer-encoding:mime-version:subject:date:references:x-mailer; b=bHkh0mn7auGipHeEZ3asbhaL4GUPrNCxFFHBItQ1i/fRr8BgnvJsJ/e/gBsIM7OTayfXJa7ZNg8VgF8aSTtceL79D7hXHuEyRcBtKx8Kw8WOjcAuNxoF2HuqLEXO4YIigpjX9HitPxoosoyu/sgpXYqvOjIt7nKrJirF4552DYE=
Try replacing
typedef CGAL::Exact_predicates_exact_constructions_kernel Static_kernel;
with
typedef CGAL::Cartesian<CGAL::Gmpq> Static_kernel;
That should shift things to use the Gmpq number type rather than the Lazy_exact_nt. The latter doesn't ever print the exact representation (as it might be quite complicated). If you can't reproduce the problem with Gmpq. there may be an issue with Laxy_exact_nt and if you can reproduce it, it should be clearer what is going on.
Sorry about the slow response, I have been at a meeting.
On Apr 25, 2008, at 6:15 AM, Mathieu Brédif wrote:
If it can help, I get an other problem that seems related in :
template<class K, class Time>
unsigned int get_multiplicity(const typename K::Function& f, const K&
k, const Time& t) {
if(f.degree() == -1) return (unsigned int) -1; // null function
typename K::Function h=f;
unsigned int deg=0;
typename K::Sign_at sign= k.sign_at_object();
typename K::Differentiate diff=k.differentiate_object();
while (sign(h, t)==CGAL::ZERO) { <---------------- throws exception
++deg;
h=diff(h);
return deg;
the exception is :
CGAL error: assertion violation!
Expr: p_(v) == 0
File: /usr/include/CGAL/Polynomial/Sturm_root_stack.h
Line: 167
the corresponding code is:
if (p_.degree() == 1) {
NT v= -p_[0]/p_[1];
CGAL_assertion(p_(v) == 0);
so it does not seem related to the particular root t but rather to the
polynom p_ and the exactness of p_[0]-p_[1]*p_[0]/p_[1]==CGAL::ZERO.
The values ouput by "std::cout <<" that cause the problem are :
f=-0.894427191-0.105572809*t
t=0
The roots that cause the problem in the previous mail were both output as :
-0.12132034356+0.192388155425*t+0.100505063388*t^2 in [0,1] = 0.5...0.5
Is there a way to backup exactly the value of a Function to be able to
reproduce my problem with a small piece of code ?
Thanks,
Mathieu
On Fri, Apr 25, 2008 at 2:17 PM, Mathieu Brédif
wrote:
Hi,
I have some trouble tracking done the cause of this precondition_exception :
Expr: s0 != CGAL::ZERO
File: /usr/include/CGAL/Polynomial/internal/Rational/ Sign_Sturm_sequence.h
Line: 57
Explanation:
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Line: 57
This exception is triggered when i am comparing 2 roots for equality.
The traits i use are :
typedef CGAL::POLYNOMIAL::Polynomial<Static_kernel::FT> Function;
typedef CGAL::POLYNOMIAL::Sturm_root_stack_traits<Function> Root_stack_traits;
typedef CGAL::POLYNOMIAL::Sturm_root_stack<Root_stack_traits> Root_stack;
typedef CGAL::POLYNOMIAL::Kernel<Function, Root_stack> Function_kernel;
Am i doing something wrong ?
thanks
Mathieu Bredif
- Precondition_exception in Sign_Sturm_sequence.h, Mathieu Brédif, 04/25/2008
- Re: Precondition_exception in Sign_Sturm_sequence.h, Mathieu Brédif, 04/25/2008
- Re: [cgal-discuss] Re: Precondition_exception in Sign_Sturm_sequence.h, Daniel Russel, 04/30/2008
- [cgal-discuss] Errors when get Facet_handle from Halfedge_around_facet_circulator, samuel kim, 04/25/2008
- Re: [cgal-discuss] Errors when get Facet_handle from Halfedge_around_facet_circulator, Mathieu Brédif, 04/25/2008
- Re: [cgal-discuss] Errors when get Facet_handle from Halfedge_around_facet_circulator, Sebastien Loriot, 04/25/2008
- RE: [cgal-discuss] Errors when get Facet_handle from Halfedge_around_facet_circulator, samuel kim, 04/25/2008
