- To:
- Subject: Re: [cgal-discuss] help using gluDisk
- Date: Sat, 03 May 2008 19:02:11 +0200
Hi,
> It works fine, draws a disk which the point coordinates of the center are
> (0,0), and that's okay.
> Suppose now I need to draw a disk at any position (x,y), how do I implement
> it?
Use glTranslate{d,f}(). You might want to have a look at a OpenGL tutorial to
understand the different transformation matrices. BTW your question is not
CGAL-related und should better be sent to an OpenGL-related mailing list.
Regards,
Joachim
- help using gluDisk, França , Mauro Sérgio Lima, 05/03/2008
- Re: [cgal-discuss] help using gluDisk, Joachim Reichel, 05/03/2008
- Re: [cgal-discuss] help using gluDisk, Bo Schwarzstein, 05/05/2008
