cgal-discuss - Re: I am new to CGAL -- was Re: [cgal-discuss] Reverse the winding of a polygon mesh?
  • To:
  • Subject: Re: I am new to CGAL -- was Re: [cgal-discuss] Reverse the winding of a polygon mesh?
  • Date: Thu, 08 May 2008 14:15:25 +0800
hello,all
I have download the demo from
http://www-sop.inria.fr/geometrica/team/Pierre.Alliez/demos/curvature/
but i found it can not run smoothly.it turns the following error:
error C2440: ¡°static_cast¡±: ÎÞ·¨´Ó¡°UINT (__thiscall CTextualStatusBar::*
)(CPoint)¡±×ª»»Îª¡°LRESULT (__thiscall CWnd::* )(CPoint)¡±
1> ´Ó»ùÀàÐ͵½ÅÉÉúÀàÐ͵ÄÇ¿ÖÆ×ª»»ÐèÒª dynamic_cast »ò static_cast
can someone help me ?
ÔÚÄúµÄÀ´ÐÅÖÐÔø¾­Ìáµ½:
>From: "Kevin Xu"
>Reply-To:
>To:
>of a
polygon mesh?
>Date:Mon, 5 May 2008 17:33:41 +0800
>Hi, Linda,
> Thank you for replying me :)
> Maybe the best way for a quick start is to download a demo with source code.
> An excellent demo for CGAL is available at:
> This demo is written by Pierre and includes loading and rendering a
> polygonal mesh. It also provides the estimation of surface curvatures.
> I hope this is helpful.
> Good luck!
> On 5/5/08, Andreas Fabri
> wrote:
> > $BU*U1(B wrote:
> > > Hi,all
> > > I am new to CGAL,I want to know how to import a polygon_3 mesh data and
> > what
> > > packages should be included.
> > Hi Linda,
> > as you are new:
> > - Never reply to a mail starting with a completely new topic.
> > - Have a look at the online manual and maybe start with the package
> > overview:
> > http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/packages.html
> > Click on "Polygons and Polyhedra"
> > In the paragraph on "3D Polyhedral Surface" you see on the right links to
> > the User and Reference Manual. The former is full of examples which
> > should
> > answer your question.
> > Best regards,
> > andreas
> > > linda
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
