cgal-discuss - Re: [cgal-discuss] help
  • To:
  • Subject: Re: [cgal-discuss] help
  • Date: Thu, 8 May 2008 19:33:59 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=vSMti0N9om/Le1kSAar6HpD8sL0OrFLaTOOHLWnC4bUj1q6BlVrXwiohVxqt6Sme5z88HMh26m05Zz/iCt6puDdcII6IPyaEH6pB65RuLU+ctYQsGoSUT2SzDEi+P5cg7RQ4Lt2QTVZWIWs+BiP4USQmqzMkYZ3ER1rTTPVlwjM=
如果还有问题,QQ:568950833. 或者MSN:
在08-5-8,Baojun Li <> 写道:
哦,如果纯粹是这个问题,双击这个错误,把对应的那条语句注释掉就可以了。
我是这么干的,没问题。
在08-5-8,姜娜 <> 写道:
在您的来信中曾经提到:
>From: "姜娜" <>
>Reply-To:
>To:
>Subject: Re: I am new to CGAL -- was Re: [cgal-discuss] Reverse the winding of a
polygon mesh?
>Date:Thu, 08 May 2008 14:15:25 +0800
> hello,all
> I have download the demo from
> http://www-sop.inria.fr/geometrica/team/Pierre.Alliez/demos/curvature/
> but i found it can not run smoothly.it turns the following errors:
> error C2440: "static_cast": 无法从"UINT (__thiscall CTextualStatusBar::*
> )(CPoint)"转换为"LRESULT (__thiscall CWnd::* )(CPoint)"
> 1>        从基类型到派生类型的强制转换需要 dynamic_cast 或 static_cast
> error C2668: "pow": 对重载函数的调用不明确
> can someone help me ?I am very worried.
Best wishes,
Li Baojun(李宝军)
Department of Applied Mathematics.
Dalian University of Technology. Dalian, China.
13322282610
Best wishes,
Li Baojun(李宝军)
13322282610
