- To:
- Subject: Re: [cgal-discuss] How to obtain the index of the point in dD spatial search
- Date: Thu, 15 May 2008 14:55:06 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=HTpMCOYQsVwQ6K57SztfgMUdgiPIgA+45m8yR+be1PDt75FwVN1xNvn/BkNbaUPmKmroRM2/FtsA1xV1gs1N88o1Xc7ywQeBVbP/9x9cj6oZZwbm7vNfln9poIgrt2bKdspXT11LwswS3uy3yZzgmttqjTYlk6CqZg1zDTekdpw=
You can write your own customized point and distance class. In the poing
class you can make a member variable (index of the point), . It will provide
an
way to do what you want. Read "user defined point and distance" section
in CGAL manual.
I have done it and it is working fine. I am attaching my code for that.
Hasan
On Sun, May 11, 2008 at 7:04 PM, Jian Sun
wrote:
> Hi Kevin,
> Thank you for your suggestion. It is very helpful. But it does not works as
> it is.
> One needs to define a comparison operator on Point.
> It serves my purpose well now, though it is different from the solution that
> I am looking for.
> I am looking for a way to customize Point_d as one does for the vertex in
> the Delaunay
> triangulation. If that is doable, we can add an index into each point, which
> avoids the
> extra step of looking up in map.
> sunjian
> On Sun, May 11, 2008 at 2:12 AM, Kevin Xu
> wrote:
>> Hi, Sun Jian,
>> You can use the map container provided by STL to achieve this.
>> Let's take the range search (with kd-tree) for example:
>> KD_tree STree; // define a kd tree for all vertices
>> std::map<Point,int> mVPToID; // map vertex pos. to index
>> std::map<Point,int>::iterator iPTI; // an iterator for mVPToID
>> // construct mapping
>> for (all vertices in a mesh or other data structure)
>> STree.insert (VP(i)); // add position of the ith vertex
>> mVPToID.insert (std::make_pair(VP(i), ID(i))); // make a map
>> between pos. & id
>> // perform range searching
>> std::vector<Point> FP; // store all found points (pos.)
>> Fuzzy_sphere fs(query_pos, dRadia, 0.0); // a fuzzy query sphere
>> STree.search(std::back_inserter(FP), fs); // do searching
>> // collect ids for the found points
>> for (int i=0; i<FP.size(); i++)
>> if ((iPTI=mVPToID.find(FP[i])) != mVPToID.end())
>> { // find the record of FP[i] to get its id
>> ID(i) = iPTI->second; // id of the ith point is "iPTI->second"
>> /// end of the routine
>> The routines for k-NN search, etc., are similar.
>> HTH.
>> Good luck!
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
Mohammad Al Hasan
2257 Burdett Ave,
Troy NY 12180
template <unsigned int D> struct Distance { typedef Point<D> Point_D; typedef Point<D> Query_item; double transformed_distance(const Point_D& p1, const Point_D& p2) const { double ret_val(0.0); for (int i=0; i<D; i++) { double tempval = p1.get_index_val(i) - p2.get_index_val(i); ret_val += tempval*tempval; } return ret_val; } template <class TreeTraits> double min_distance_to_rectangle(const Point_D& p, const CGAL::Kd_tree_rectangle<TreeTraits>& b) const { double distance(0.0); for (int i=0; i<D; i++) { double h = p.get_index_val(i); if (h < b.min_coord(i)) distance += (b.min_coord(i)-h)*(b.min_coord(i)-h); if (h > b.max_coord(i)) distance += (h-b.max_coord(i))*(h-b.max_coord(i)); } return distance; } template <class TreeTraits> double max_distance_to_rectangle(const Point_D& p, const CGAL::Kd_tree_rectangle<TreeTraits>& b) const { double distance(0.0); for (int i=0; i<D; i++) { double h = p.get_index_val(i); double tempval = (h >= (b.min_coord(i)+b.max_coord(i))/2.0) ? (h-b.min_coord(i))*(h-b.min_coord(i)) : (b.max_coord(i)-h)*(b.max_coord(i)-h); distance += tempval; } return distance; } double new_distance(double& dist, double old_off, double new_off, int cutting_dimension) const { return dist + new_off*new_off - old_off*old_off; } double transformed_distance(double d) const { return d*d; } double inverse_of_transformed_distance(double d) { return std::sqrt(d); } }; // end of struct Distance
#include <iostream> using namespace std; typedef unsigned int UINT; template<UINT MAXSIZE> struct Point; template<UINT MAXSIZE> ostream& operator<< (ostream&, const Point<MAXSIZE>& p); template <UINT MAXSIZE> struct Point { int id; double vec[MAXSIZE]; Point() { for (int i=0; i<MAXSIZE; i++) vec[i]= 0; } unsigned int dimension() const { return MAXSIZE;} const double * get_data() const { return vec;} Point(int id, double input[]) { this->id = id; for (int i=0; i<MAXSIZE; i++) vec[i]= input[i]; } double get_index_val(int i)const {return vec[i];} friend ostream& operator << <>(ostream&, const Point<MAXSIZE>&); bool operator==(const Point& p) const { for (int i=0; i<MAXSIZE; i++) if (vec[i] != p.vec[i]) return false; return true; } bool operator!=(const Point& p) const { return ! (*this == p); } }; template<unsigned int MAXSIZE> ostream& operator<< (ostream& ostr, const Point<MAXSIZE>& p) { ostr << p.id; }
//file: examples/Spatial_searching/User_defined_point_and_distance.C #include <CGAL/basic.h> #include <CGAL/Search_traits.h> #include <CGAL/Orthogonal_k_neighbor_search.h> #include <CGAL/Fuzzy_sphere.h> #include "MyPoint.h" // defines types Point, Construct_coord_iterator #include "MyDistance.h" typedef Point<5> Point_D; typedef Distance<5> Distance_D; namespace CGAL { template <> struct Kernel_traits<Point_D> { struct Kernel { typedef double FT; typedef double RT; }; }; } struct Construct_coord_iterator { const double* operator()(const Point_D& p) const { return static_cast<const double*>(p.vec); } const double* operator()(const Point_D& p, int) const { int dim = p.dimension(); return static_cast<const double*>(p.vec+dim); } }; typedef CGAL::Search_traits<double, Point_D, const double*, Construct_coord_iterator> Traits; typedef CGAL::Fuzzy_sphere<Traits> Fuzzy_sphere; typedef CGAL::Orthogonal_k_neighbor_search<Traits, Distance_D > K_neighbor_search; typedef K_neighbor_search::Tree Tree; int main() { const int N = 1000; const int K = 3; // generator for random data points in the cube ( (-1,-1,-1), (1,1,1) ) // Random_points_iterator rpit( 5); std::list<Point_D> points; double p1d[5] = {1,0,0,0,0};Point_D p1(1, p1d); double p2d[5] = {0,2,0,0,0};Point_D p2(2, p2d); double p3d[5] = {0,0,3,0,0};Point_D p3(3, p3d); double p4d[5] = {0,0,0,4,0};Point_D p4(4, p4d); double p5d[5] = {0,0,0,0,5};Point_D p5(5, p5d); points.push_back(p1); points.push_back(p2); points.push_back(p3); points.push_back(p4); points.push_back(p5); // Insert number_of_data_points in the tree Tree tree(points.begin(),points.end()); double query_data[5] = {1,0,0,0,0}; Point_D query(0, query_data); Distance_D tr_dist; // search K nearest neighbours K_neighbor_search search(tree, query, K); for(K_neighbor_search::iterator it = search.begin(); it != search.end(); it++){ std::cout << " d(q, nearest neighbor)= " << it->first << "," << tr_dist.inverse_of_transformed_distance(it->second) << std::endl; } // search K furthest neighbour searching, with eps=0, search_nearest=false K_neighbor_search search2(tree, query, K, 0.0, false); for(K_neighbor_search::iterator it = search2.begin(); it != search2.end(); it++){ std::cout << " d(q, furthest neighbor)= " << tr_dist.inverse_of_transformed_distance(it->second) << std::endl; } Fuzzy_sphere exact_range(query, 3); std::list<Point_D> result; tree.search(std::back_inserter( result ), exact_range); std::cout << "The points in the circle centered at (0,0) is :"; std::copy(result.begin(), result.end(), std::ostream_iterator<Point_D>(std::cout, " ")); std::cout << std::endl; return 0; }
- How to obtain the index of the point in dD spatial search, Jian Sun, 05/11/2008
- Re: [cgal-discuss] How to obtain the index of the point in dD spatial search, Kevin Xu, 05/11/2008
- Re: [cgal-discuss] How to obtain the index of the point in dD spatial search, Jian Sun, 05/12/2008
- Re: [cgal-discuss] How to obtain the index of the point in dD spatial search, Kevin Xu, 05/12/2008
- Re: [cgal-discuss] How to obtain the index of the point in dD spatial search, Al Hasan, 05/15/2008
