- To:
- Subject: Re: [cgal-discuss] Debugger available?
- Date: Tue, 20 May 2008 09:34:35 +0200
Hello,
I insert the "-g" option in the Makefile, where the CC and LD options are
(perhaps removing the "-O" option, I don't know if this is really needed,
try). The resulting code can be debugged. I use the text debugger gdb, but I
think DDD should work.
Best,
Daniel
On Tuesday 20 May 2008 00:13:01 Amit Pendharkar wrote:
> Hi All,
> I want to use some graphical debugger to see how CGAL library functions.
> Can I use some debugger like DDD? How to set it up?
> I need to go through the functionality implemented in the library files but
> doing it manually eats up lot of time.
> Thanks & Regards,
> Amit Pendharkar
Daniel Duque
http://rincon.uam.es/dir?cw=950067138671875
- Debugger available?, Amit Pendharkar, 05/20/2008
- Re: [cgal-discuss] Debugger available?, Daniel Duque Campayo, 05/20/2008
- Re: [cgal-discuss] Debugger available?, Amit Pendharkar, 05/21/2008
