- To:
- Subject: Re: [cgal-discuss] Opengl with cgal 3.3.1 on Mac OS X Leopard
- Date: Thu, 29 May 2008 23:39:57 -0400
I sent that first email off a little too quick. I had trouble compiling qt3 on Leopard as well, but I found the instructions on this page to be useful. Basically apply a patch and it's good to go:
http://hans.fugal.net/blog/articles/2008/03/26/qcad-on-leopard
It is apparently enough to get qt to compile, though the demos don't seem to be running right. It doesn't seem to accept mouse clicks or something. Try at your own risk I guess.
Cheers,
Steve
On May 29, 2008, at 7:31 PM, Steven Peters wrote:
Hi,
I've just finished building CGAL 3.3.1 on Mac OS X Leopard 10.5.2. In the default build, there was a linking error for the opengl libraries. Specifically, it says:
ld: cycle in dylib re-exports with /usr/X11R6/lib/libGL.dylib
collect2: ld returned 1 exit status
This error is discussed on the apple developer website linked to below. It can be circumvented by adding an LDflag. I changed the config/support/S70-OPENGL file to include this LDflag and it fixed the problem.
http://developer.apple.com/qa/qa2007/qa1567.html
Should I send a patch or something?
Cheers,
Steve Peters
- Opengl with cgal 3.3.1 on Mac OS X Leopard, Steven Peters, 05/30/2008
- Re: [cgal-discuss] Opengl with cgal 3.3.1 on Mac OS X Leopard, Steven Peters, 05/30/2008
- Re: [cgal-discuss] Opengl with cgal 3.3.1 on Mac OS X Leopard, Olivier Devillers, 05/30/2008
