cgal-discuss - Re: [cgal-discuss] cannot run kinetic data structure example: manifest error
  • To: <>
  • Subject: Re: [cgal-discuss] cannot run kinetic data structure example: manifest error
  • Date: Fri, 6 Jun 2008 10:54:10 -0300
  • Organization: Geometry Factory
Hello Hui,
Hi all,
I am a beginner to CGAL and I was trying to run the example program under
kinetic_data_structure/delaunay_triangulation_2.
It compiles OK but when I try to execute, I got the following message:
Unable to start program '......'
This application has failed to start because the application configuration
is incorrect. Review the manifest file for possible errors. Reinstalling
the application may fix this problem. For more details, please see the
application event log.
Can anyone please tell me how can I fix this?
I used the CGAL3.3.1 windows installer and compile the code on Visual
Studio 2005.
There is a known problem with the precompiled gmp/mpfr *debug* libraries distributed by the CGAL installer.
Can you try compiling in Release mode instead?
HTH
Fernando Cacciola
GeometryFactory
