cgal-discuss - [cgal-discuss] CGAL and Threadsafety
  • To: <>
  • Subject: [cgal-discuss] CGAL and Threadsafety
  • Date: Sun, 8 Jun 2008 13:06:53 +0200
Hi!
I want to use CGAL´s Delaunay Triangulation inside multiple threads
where each thread can run on a different CPU. I use boost::thread and the
threadpool from threadpool.sf.net.
What do I need to obey if I want to use CGAL with multiple threads? How
threadsafe are the triangulatione etc.?
I get various signal 11 errors when I e.g. ask for the dual of a Delaunay
Triangulation face and so on. Errors like this:
*** glibc detected *** corrupted double-linked list: 0x0d1f81b8 ***
Core dump says:
#0 0x0819dbac in _int_malloc ()
#1 0x0819f7e6 in malloc ()
#2 0x08172af8 in operator new ()
#3 0x080d3e04 in
CGAL::Lazy_construction<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> >,
CGAL::Cartesian_converter<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::To_interval<CGAL::Gmpq> > >,
CGAL::CommonKernelFunctors::Construct_segment_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::CommonKernelFunctors::Construct_segment_3<CGAL::Simple_cartesian<CGAL::Gmpq>
>::operator()<CGAL::Point_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::To_interval<CGAL::Gmpq> > > >,
CGAL::To_interval<CGAL::Gmpq> > > > > ()
#4 0x080d7cb6 in
CGAL::DT3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::TDS3<CGAL::TH_vb3<CGAL::Triangulation_vertex_base_with_info_3<boost::shared_ptr<Isp>,
CGAL::T_vb3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::To_interval<CGAL::Gmpq> > >, CGAL::TDS_vb3<void> > > >,
CGAL::Triangulation_cell_base_with_info_3<boost::shared_ptr<DCellProperty>,
CGAL::T_cb3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::To_interval<CGAL::Gmpq> > >, CGAL::TDS_cb3<void> > > > >::dual ()
#5 0x080cafd0 in DFacetProperty::setDual ()
#6 0x080d9143 in DCellProperty::insertFacets ()
#7 0x080dd258 in CComponent::dtriangulate ()
#8 0x080ddafa in CComponent::doWork ()
#9 0x0805d4bc in boost::function0<void, std::allocator<boost::function_base>
>::operator() ()
#10 0x0805d955 in
boost::threadpool::detail::worker_thread<boost::threadpool::detail::pool_core<boost::function0<void,
std::allocator<boost::function_base> >, boost::threadpool::fifo_scheduler,
boost::threadpool::static_size, boost::threadpool::resize_controller,
boost::threadpool::wait_for_all_tasks> >::run ()
#11 0x0805d4bc in boost::function0<void, std::allocator<boost::function_base>
>::operator() ()
#12 0x080f94de in thread_proxy ()
#13 0x0817e8f4 in pthread_start_thread (arg=0x13966840) at manager.c:310
#14 0x081ae73a in clone ()
Any ideas what can be wrong? (It works very fine if the code runs with
multiple threads on ONE CPU, but it starts failing if the threads are
distributed among 2 or more CPUs)
Best regards,
,yours Thomas Zangl, Bakk.rer.soc.oec. -
- Freelancer - IT Consulting & Software Development -
- Student of Software Development-Economy (Master) -
- http://blog.tzis.net -
