- To:
- Subject: Re: [cgal-discuss] Missing lib
- Date: Wed, 18 Jun 2008 12:56:13 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=VnM8zjBXYLXuxUrs/aq7Vo96wQlaAjKGpSj4XVtmMLaArWk7BbXGI8CkGHSGmnKlWB vAM8UCYyCwjp2uWGixSc8TkCwcL3GunRMH0K7keGibj6AXlC482Q5K5gXXgBJ9wfu2rk KWTHa1e92EwM//9J+/HwUNPUt6xqY/5T0F77E=
hi Yoann
i'm using cgal with Microsoft visual studio 2008. i guess you don't
need to compile boost by yourself. i downloaded the setup packages.
and everything is easy.
for boost, check this out http://www.boost-consulting.com/products/free
for cgal, use the installer too.
good luck.
On Tue, Jun 17, 2008 at 11:23 PM,
wrote:
> Hi all,
> I'm a student using CGAL 3.3.1, with Boost 1_35_0,
> qt-win-free-msvc.net2003-3.3.3 and Microsoft Visual 2003.
> I had lots of problems (links, libs, environnment variables) to compile some
> demos: some were fixed, others not really...One of them is a missing library
> called "libboost_program_options-vc71-mt-gd-1_35.lib" in the demo
> "Kinetic_data_structures".
> I tried to compile boost lib with Bjam, but still can't find this one. Do
> you
> have any ideas or advices in order to find a solution ??
> And BTW, is it possible to compile EVERY demos with a working and simple
> configuration; and if yes, which one :) ?
> Thanks a lot,
> Yoann
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Missing lib, ihavefoundthepeace, 06/17/2008
- Re: [cgal-discuss] Missing lib, Bill Conan, 06/18/2008
