- To:
- Subject: Re: [cgal-discuss] Regular operations : intersection of two simple
- Date: Wed, 18 Jun 2008 18:47:06 +0200
amit tripathi a écrit :
hi list.............
Thanks for response....................i am attaching the test input file
p4.dat and source file simple_join_intersect.cpp ...................when i run it under example Boolean_set_operations_2 .......................i got following output...............floating point exception.........(this is the test case when two polygons are touching......)...............
USAGE:executable inputfile
[root@localhost command_lineBoolean_set_operations_2]# ./simple_join_intersect p4.dat
Floating point exception
[root@localhost
thanks alot.................
Could you please fix the "." key of your keyboard?
This makes your messages unreadable.........
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] Minkowski'sum : offsetting a polygon, amit tripathi, 06/17/2008
- Re: [cgal-discuss] Minkowski'sum : offsetting a polygon, efif, 06/18/2008
- [cgal-discuss] Minkowski'sum : offsetting a polygon, amit tripathi, 06/18/2008
- [cgal-discuss] Regular operations : intersection of two simple polygons, amit tripathi, 06/18/2008
- Re: [cgal-discuss] Regular operations : intersection of two simple, Sylvain Pion, 06/18/2008
- <Possible follow-up(s)>
- Fw: [cgal-discuss] Minkowski'sum : offsetting a polygon, amit tripathi, 06/18/2008
