cgal-discuss - Re: [cgal-discuss] i'm confused about the Edge
  • To:
  • Subject: Re: [cgal-discuss] i'm confused about the Edge
  • Date: Fri, 20 Jun 2008 15:40:16 +0800
Bill Conan wrote:
i'm a little confused with the Edge. is there any Edge data structure
that is explicitly implemented in the CGAL?
No.
my problem is i need to add some attribute to the Edge like this:
but i'm wondering, if i travel all the edges in this way, and give
each edge a color
then is that true that only half of the half-edges are assigned the color red?
Yes.
and which half-edge of the two half-edges of an Edge can be visited by
the edge iterator? is there any rule behind?
If the half edges are {0, 1, 2, 3, 4, 5}, the edge iterator visits {0, 2, 4}. The edge iterator and the half edge iterator access the same half edge data structure. The edge iterator just skips 2 items instead of 1 when you apply the ++ operator to it.
say if at the beginning i let all the edges in red. and then i split
some random edges of the geometry.
and i assign the all the splitted edge to be in red too.
and now i if i travel all the edges again,
can i make sure all the edges i traveled are in red?
I couldn't understand your query.
~ash
