- To:
- Subject: [cgal-discuss] Triangular mesh offsetting
- Date: Thu, 26 Jun 2008 09:29:09 -0400 (EDT)
- Importance: Normal
Can I use CGAL to perform triangular mesh offsetting?
If not, can anyone suggest any other library/source-code that I can use to
perform the offset operation.
I want to create an envelope around triangulated geometry with a specified
clearance.
I can write the code to offset the vertices by using normals computed from
the facets. But, it would create many intersections in the mesh.
I found two papers that deal with triangular mesh offsetting, but couldn't
find the code. Here are the papers.
Offset Triangular Mesh Using the Multiple Normal Vectors of a Vertex
http://www.cadanda.com/V1Nos1to4_33.pdf
Self-intersection Removal in Triangular Mesh Offsetting
http://www.cadanda.com/V1Nos1to4_54.pdf
Can anyone suggest me any resource that I can use to offset a triangular
mesh?
Thanks.
- [cgal-discuss] little problem, amit tripathi, 06/26/2008
- [cgal-discuss] Triangular mesh offsetting, Santosh Tiwari, 06/26/2008
