- To:
- Subject: Re: [cgal-discuss] Postcript output outside of distribution ?
- Date: Thu, 26 Jun 2008 20:00:19 +0300
Apparently, the file Arr_postscript_file_stream.h should not be part of the distribution as well.
I believe that all postscript support that was based on LEDA got deprecated.
Bertrand Nouvel wrote:
Dear members of CGAL development team,--
There is apparently some files missing in the current distribution of CGAL.
I cannot find out the file :Postscript_file_stream.h
It is obviously needed within Arr_postscript_file_stream.h
/usr/include/CGAL/IO/Arr_postscript_file_stream.h:26:44: error: CGAL/IO/Postscript_file_stream.h: No such file or directory
I am using ubuntu 8.04, and I used first the package from the repository.
Then I tries to download the "tar.gz" of the source from the webpage.
But the file did not seem to be present in the source archive.
I find it quite strange that the current version of CGAL lacks postscript support...
But I haven't found out anything related while browsing around.
Best regards,
Bertrand Nouvel
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
This e-mail message may contain information which is CONFIDENTIAL, privileged
or proprietary to Lucidlogix Technologies, Ltd. and is subject to
restrictions on disclosure and use. If you have received this e-mail message
in error, please notify the sender immediately by telephone or e-mail and
destroy the original message without making a copy. Thank you.
- [cgal-discuss] Postcript output outside of distribution ?, Bertrand Nouvel, 06/20/2008
- Re: [cgal-discuss] Postcript output outside of distribution ?, Ashwin Nanjappa, 06/21/2008
- Re: [cgal-discuss] Postcript output outside of distribution ?, Efi Fogel, 06/26/2008
