- To:
- Subject: Re: [cgal-discuss] Ambigous reference to Weighted_Point during compilation
- Date: Wed, 2 Jul 2008 22:48:22 +0200
On Tuesday 01 July 2008 17:08:31 Thomas Zangl - Home wrote:
> Am Tue, 1 Jul 2008 13:45:42 +0200, schrieb "Laurent Rineau"
> Hi!
> >Your compiler is wrong, unless you have "using namespace CGAL;" somewhere
> > (in which case *you* are wrong).
> 100% correct - I had a using namespace CGAL; in it. Removed it - works.
The other solution, if you still want to use "using namespace CGAL;", is to
rename your typedef. :-)
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Ambigous reference to Weighted_Point during compilation, Thomas Zangl - Home, 07/01/2008
- Re: [cgal-discuss] Ambigous reference to Weighted_Point during compilation, Monique . Teillaud, 07/01/2008
- Re: [cgal-discuss] Ambigous reference to Weighted_Point during compilation, Laurent Rineau, 07/01/2008
- Re:[cgal-discuss] Ambigous reference to Weighted_Point during compilation, Thomas Zangl - Home, 07/01/2008
- Re: [cgal-discuss] Ambigous reference to Weighted_Point during compilation, Laurent Rineau, 07/02/2008
