- To: "cgal-discuss" <>
- Subject: Re:[cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
- Date: Thu, 3 Jul 2008 12:56:57 +0200
Am Thu, 03 Jul 2008 10:06:29 +0200, schrieb "Andreas Fabri"
Hi!
>The lazy exact kernel stores DAGs (directed acyclic graph) of geometric and
>arithmetic operations.
Is that the expresion to compute some predicate?
>Each node of the DAG stores
>- a geometric object or number with intervals of doubles,
>- the type of the geometric or arithmetic operation
>- pointers to the DAG nodes representing the operands of the
>geometric/arithmetic
> operation
>When a predicate on a lazy object fails the postponed exact computation
>is replayed from the information stored in the DAG.
So, the lazy object is more or less a caching?
E.g. if I query the lazy kernel for the intersection between two
identical segments a few times, only the first intersection test is
made and all subsequent tests are returned from the DAG but only if the
two segments remain unchanged?
>The Filtered_kernel only provides exact predicates, that is all
>constructions
>are double constructions.
How can it be then that the Exact_constr._exact_pred. kernel uses a
defintion like this:
typedef Lazy_kernel<Simple_cartesian<Gmpq> >
Exact_predicates_exact_constructions_kernel;
The constructions are done using Gmpq so they are considered exact,
arent they? If thats true, the filtered_kernel does only predicates and
needs an exact number type like Gmpq to produce exact construction,
true?
Is my conclusion true:
Filtered_kernel<Simple_cartesian<Lazy_exact_nt<Gmpq > > > : first,
use a cheap (semi-)static filter, then fall back to the lazy kernel
(Interval arithmetic) and finally use exact computations.
Lazy_kernel<Simple_cartesian<Gmpq> > : first try to use the lazy
kernel and then fall back to exact computations.
>So to compare their performance doesn't really make sense. The latter is
>faster but provides no exact constructions.
Ok. My goal was to show that different kernels (and the way how
filters are chained) influence the runtime. So I can compare a
Simple_cartesian<Gmpq> along with a Lazy_kernel<Simple_cartesian<Gmpq>
and conclude about it effect (I bet it will give a speedup) ? Is this
true?
TIA,
,yours Thomas Zangl, Bakk.rer.soc.oec. -
- Freelancer - IT Consulting & Software Development -
- Student of Software Development-Economy (Master) -
- http://blog.tzis.net -
- [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Thomas Zangl - Home, 07/02/2008
- Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Andreas Fabri, 07/03/2008
- Re:[cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Thomas Zangl - Home, 07/03/2008
