- To:
- Subject: Re: [cgal-discuss] point lying over a line problem
- Date: Wed, 23 Jul 2008 19:02:40 +0200
Alejandro Aragon a écrit :
I see your point but as soon as you start using double precision, the "mathematical sense" is out of question, right?
That's the naive view. A double value has a real (exact) value
(except NaNs and infinities). That is a fact.
Most (if not all) CGAL algorithms are designed with the model that the
input is known exactly, and compute the exact answer. They are proved
in the literature in this model.
Defining computational geometry structures and algorithms in a fuzzy model
has been done for some problems in the literature, but it is way less
generally used in computational geometry, and CGAL does not support it so far.
And it is hard.
So that a < b is not true if they are within tolerance. Also, what is the chance that your algorithms encounter something like what you described, where in "mathematical sense" a < b < c and then you think CGAL has a bug because it's not giving you the answer you expect? Instead, if you use a type that is not exact, you would expect algorithms to behave with the same degree of "exactness". I guess that is what users would expect, at least that is what I expect. If they want a more exact predicate, then use an "exact" type.
Depends on your needs. How do you define this tolerance?
(note that interval arithmetic can be used with CGAL, but this is not double,
this is slower, but this gives guarantees).
Tell us more about your problem.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- Re: [cgal-discuss] point lying over a line problem, (continued)
- Re: [cgal-discuss] point lying over a line problem, Andreas Fabri, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Alejandro Aragon, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Sylvain Pion, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Olivier Devillers, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Fernando Cacciola, 07/23/2008
