cgal-discuss - Re: [cgal-discuss] point lying over a line problem
  • To:
  • Subject: Re: [cgal-discuss] point lying over a line problem
  • Date: Wed, 23 Jul 2008 14:28:36 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:from:to:in-reply-to:content-type :content-transfer-encoding:mime-version:subject:date:references :x-mailer; b=xPNRgiRpxRQCG3zrbB7Hdiuc5vBrh9l5vU3Q7d2l8dU9MDsTyqX3GHIJBO+qx8uTKU 6RvR3s1tMQPDlPue329htdbrXplL+ZKdWuo9G1VM+tvPXku1uLYzPmUIvuKWv34oN47q TxtzvGiOTX7fhqm1MYOxmUEJHwky1n1cBWPRA=
So there are indeed a billion files!
On Jul 23, 2008, at 1:21 PM, Sylvain Pion wrote:
Alejandro Aragon a écrit :
Do you know where is the code that computes this predicate??? Where exactly is defined the oriented_side function? I tried to find it but it is obfuscated inside a million header files.
Have you tried a debugger to drive you through the billion files?
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
