- To: <>
- Subject: [cgal-discuss] Polyhedron Join
- Date: Fri, 25 Jul 2008 14:12:52 +0100
Hi everyone, I couldn’t understand a simple operation in CGAL. Say
you have 2 very stretched & thin triangles formed from triangulation and
you want to eliminate the longest edge shared between them. As I understood the
operation should be join_facets(). However I was wondering what the outcome
would be? The newly joined facet may not have its 4 points located on the same
plane because the 2 adjacent triangles weren’t. In this case (and many
other polyhedral operations), will the coordinates of the vertices also be
changed automatically? Or are some other manual procedures required? Regards, Xiaofan |
- [cgal-discuss] Polyhedron Join, Xiaofan Li, 07/25/2008
