- To:
- Subject: [cgal-discuss] CGAL with SUN CC and aCC compilers
- Date: Wed, 30 Jul 2008 14:47:51 +0200 (CEST)
Hi,
I'd like to know if there is any prerequisite to compile a CGAL project with
SUN CC.
I'm currently on SUNOS 5.10 with SUNPRO 5.7.
$ CC –V
CC: Sun C++ 5.7 Patch 117830-02 2005/03/30
I had an "ambiguity" issue but the workout works fine.
#define CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG 1
And now, I’m getting this error:
>> Assertion: (../lnk/tmplmatchargs.cc, line 178)
while processing myfile.cpp at line 232.
*** Error code 1
I think SUN patches can resolve this issue.
Unfortunately, and for my own specifics reasons, I need to know first if there
is any other workaround, without these patches.
http://sunsolve.sun.com/search/document.do?assetkey=1-21-117830-17-1
(from 117830-03)
6273787 Assertion: (../lnk/tmplmatchargs.cc, line 178) for member template
specialization
By the way, if you know anything about prerequisite for aCC (on HP-UX
B.11.11),
I’ll be glad to read about it too, because boost tells me
"error "Compiler version not supported - version A.03.80 or higher is
required"
and then a lot of cgal and boost issues appear...
and once again updating the compiler should be my last option :-(
Note : the test file i'm using right now is just a "hello world" and some cgal
includes I need. No other specific stuff.
Thanks.
- [cgal-discuss] CGAL with SUN CC and aCC compilers, gaetan.thiebaud, 07/30/2008
- Re: [cgal-discuss] CGAL with SUN CC and aCC compilers, Laurent Rineau, 07/30/2008
