- To:
- Subject: Re: [cgal-discuss] alphashapes edges into file
- Date: Wed, 06 Aug 2008 16:14:46 +0200
Hi Andi,
edges are represented as a triple of a cell and two indices determining two vertices in this cell. Thus they don't contain any functionality on their own.
The easiest solution that comes to my mind is to get the two points from the edge:
Point p = (*it).first->vertex((*it).second)->point();
Point q = (*it).first->vertex((*it).third)->point();
and then output them in whatever format you want.
Hope this helps
Manuel
wrote:
Hello,
I have a set of points and use alphashapes to get the boundary of these
points.
as.get_alpha_shape_edges(std::back_inserter(edges),
Alpha_shape_3::SINGULAR);
But how can I write the edges into a file that I can have look on them in
grass
gis for example?
for(it = edges.begin(), it != edges.end(); ++it)
cout << *it << endl;
does not work.
Does anybody know how to do it??
Thanks
Andi
- [cgal-discuss] alphashapes edges into file, andruit, 08/06/2008
- Re: [cgal-discuss] alphashapes edges into file, Manuel Caroli, 08/06/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] alphashapes edges into file, andruit, 08/07/2008
