cgal-discuss - [cgal-discuss] Several shapes of point cloud by using alphashapes
  • To:
  • Subject: [cgal-discuss] Several shapes of point cloud by using alphashapes
  • Date: Thu, 7 Aug 2008 12:36:49 +0200 (CEST)
Hello,
I am a newbie in CGAL and I have a question concerning Alphashapes.
I have set of about 1 million points, containing several roof planes. i would
like to get the shape of each roof plane. is it possible to get the shape by
using alphashapes.
I wrote the following function, but I don know if it is the right way to get
I don`t have much experience using alphashapes and CGAL, but maybe somebody of
you has.
void alphashapes(struct points input[], const char *outputfile, int
pointCount){
//open file
ofstream outfile(outputfile, ios::app);
if(!outfile) { // file couldn't be opened
cerr << "Error: file could not be opened" << endl;
exit(1);
//variables
Delaunay_hierarchy dt;
Point p;
std::list<Edge> edges;
std::list<Edge>::iterator it;
for(int i = 0; i<pointCount; i++){
int out = i;
p=Point((double)input[out].X, (double)input[out].Y,
(double)input[out].Z);
dt.insert(p);
std::cout << "Delaunay computed." << std::endl;
// compute alpha shape
Alpha_shape_3 as(dt,);
std::cout << "Alpha shape computed in REGULARIZED mode by defaut."
<< std::endl;
// find optimal alpha values
Alpha_shape_3::NT alpha_solid = as.find_alpha_solid();
Alpha_iterator opt = as.find_optimal_alpha(1);
std::cout << "Smallest alpha value to get a solid through data points
is "
<< alpha_solid << std::endl;
std::cout << "Optimal alpha value to get one connected component is "
<< *opt << std::endl;
as.set_alpha(*opt+5.5);
as.get_alpha_shape_edges(std::back_inserter(edges),
Alpha_shape_3::REGULAR);
cout << "edges Size: " << edges.size() << endl;
for(it = edges.begin(); it != edges.end(); ++it) {
Point p1=(*it).first->vertex((*it).second)->point();
Point q=(*it).first->vertex((*it).third)->point();
cout << fixed;
cout << setw(2) << setprecision(2);
cout<< p1 << endl;
cout << q << endl;
as.clear();
edges.clear();
dt.clear();
outfile.close();
Thanks.
Andi
  • [cgal-discuss] Several shapes of point cloud by using alphashapes, andruit, 08/07/2008
