cgal-discuss - [cgal-discuss] drawing of the polygon/segment voronoi diagram
  • To: <>
  • Subject: [cgal-discuss] drawing of the polygon/segment voronoi diagram
  • Date: Fri, 15 Aug 2008 12:40:32 -0400
Hello,
I’m working with the polygon Delaunay graph demo. I’m presently trying to understand how the drawing function works. I have problems with the following code, which is in the pdg_draw.h file:
  typename T::Finite_edges_iterator eit = sdg.finite_edges_begin();
  for (; eit != sdg.finite_edges_end(); ++eit) {
      if ( eit->first->vertex( sdg.cw(eit->second) )->info() !=
       eit->first->vertex( sdg.ccw(eit->second) )->info() ) {
            {sdg.draw_dual_edge(*eit, widget);}
I have two questions :
  1. The iterator declared here allows to visit the edges of the DELAUNAY graph, not the edges of the Voronoï graph. But the drawing function (draw dual edge) takes a VORONOI edge in parameter, not a Delaunay edge, and draws that edge to a stream. I know the Voronoï and Delaunay diagrams are dual, but a Delaunay edge is not an edge in the Voronoï diagram. So, what is the trick here? Maybe the draw_dual_edge function receives a Delaunay edge in parameter, but draws its dual edge (i.e. a Voronoï edge) to the stream? The doc is a bit unclear on this point.
2. I modified the demo so that all the segments of a polygon have the same ID (the sites “info”). The drawing function works like a charm, it draws only the lines of the polygon Voronoï cells, instead of drawing all the diagram lines (skeleton lines, segment Voronoï cells), as can be seen in the print screen I joined to this mail. But I don’t understand how the “if” condition works in the code above. Can someone explain it to me?
Thank you, any input is really appreciated!
Karine
MSc student, geomatics
Université Laval
Attachment: voronoi for polygons.gif
Description: GIF image
  • [cgal-discuss] drawing of the polygon/segment voronoi diagram, karine hins-mallet, 08/15/2008
