- To:
- Subject: Re: [cgal-discuss] Cells of regular triangulation 3
- Date: Tue, 19 Aug 2008 19:53:35 +0200 (CEST)
- Importance: Normal
I am affraid "additevely weighted" reffers to the so-called Appolonius
diagram (hyperboloïdal boudaries), in which case -to my knowledge- CGAL
only supports the 2D case.
--Ben
> You are on the good track if what you call an
> "additevely weighted Voronoi diagram" is a power diagram,
> i. e' a diagram where the distance between the two
> weighted point (p,w) and (p',w') is assumed to be
> d = (p-p')^2 -w - w'.
> CGAL regular triangulation is just the dual of the power diagram
> and CGAL will let you access to the cells of the power diagram
> through the dual functions of the regular triangulations.
> For instance you will get the vertices of the power cell
> of a sites (p,w) by calling the dual function on
> the tetrahedra of the regular triangulation incident to
> the vertex associated with (p.w).
> Hope this helps.
> wrote:
>> Dear all,
>> I am a bit new to both C++, STL and CGAL and have a few questions
>> concerning
>> the weighted regular triangulation. I tried both Google, the CGAL manual
>> and
>> the mailinglist archieve but I could not find anything.
>> First of all, I am trying to generate a socalled additively weighted
>> Voronoi
>> diagram in 3D. For this I am trying to extend the code given in the
>> example
>> directory in CGAL "examples/Triangulation_3/example_regular.C". Am I on
>> the
>> right track or is it completely wrong?
>> Second, when I have a variable of type "Regular_triangulation_3", how
>> can I
>> access the individual cells?
>> Thank you,
>> Allan
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Cells of regular triangulation 3, allan.lyckegaard, 08/19/2008
- Re: [cgal-discuss] Cells of regular triangulation 3, Mariette Yvinec, 08/19/2008
- Re: [cgal-discuss] Cells of regular triangulation 3, schwarz, 08/19/2008
- Re: [cgal-discuss] Cells of regular triangulation 3, Allan Lyckegaard, 08/20/2008
- Re: [cgal-discuss] Cells of regular triangulation 3, Monique . Teillaud, 08/20/2008
