- To: <>
- Subject: [cgal-discuss] Drawing of the Segment Voronoi Diagram
- Date: Wed, 20 Aug 2008 10:39:37 -0400
Hi, In the Polygon Delaunay Graph demo, there is a
Drawing function which draws the Voronoï cells of the diagram. This is the code
of the function: typename
T::Finite_edges_iterator eit = sdg.finite_edges_begin(); for (; eit !=
sdg.finite_edges_end(); ++eit) { if (
eit->first->vertex( sdg.cw(eit->second) )->info() != eit->first->vertex(
sdg.ccw(eit->second) )->info() ) { {sdg.draw_dual_edge(*eit,
widget);} In that code, I understand that a test is performed
on all the edges of the Delaunay graph, and that if the test succeeds then the
dual Voronoï edge is drawn. But what I don’t understand is what is done
(or checked) in the “if” test. Can someone explain it to me? Thank you so much, Karine |
- [cgal-discuss] Drawing of the Segment Voronoi Diagram, karine hins-mallet, 08/20/2008
- Re: [cgal-discuss] Drawing of the Segment Voronoi Diagram, Olivier Devillers, 08/20/2008
