cgal-discuss - Re: [cgal-discuss] Determining if the intersection between two planes is convex
  • To:
  • Subject: Re: [cgal-discuss] Determining if the intersection between two planes is convex
  • Date: Tue, 26 Aug 2008 15:26:20 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=BgdRiAdU//kXg7ww3KGZLoFhXY4/p0pZgP6YBIhOtSRv75h0eQHhwGLOYAdsjKeCzD veaFMNjjPQk3IJXS60+0T4CuQDRT+I46ncNmmbT1QN1Z+xHJSC0ENe5uwVJ6+Dd1zx3d bgfXKBP49CtAvQRVzGQ/uiir5eOcOfqHctvU4=
As far as I understand, this problem is easy : any 2 oriented planes,
in a non degenerate setup, may form both a reflex or a non reflex
edge :
let say the 2 planes are x=0 and y=0 (oriented normals (1,0,0) and (0,1,0) ),
then they can form either
- the reflex edge between the halfplanes {(0,y,z)/y>=0} and {(x,0,z)/x>=0}
- the non-reflex edge between the halfplanes {(0,y,z)/y<=0} and {(x,0,z)/x<=0}
Mathieu
On Mon, Aug 25, 2008 at 3:59 PM, Amir Vaxman
wrote:
> Suppose I have two oriented planes in 3D, and I wish to know if the
> intersecting line between them is reflex or not (if they both were faces of
> some polyhedron, and it was the edge between them, but I don't have any
> other edge or face available). How can I achieve that?
> Amir.
