cgal-discuss - Re: [cgal-discuss] constrained 3D surface mesh
  • To:
  • Subject: Re: [cgal-discuss] constrained 3D surface mesh
  • Date: Thu, 28 Aug 2008 11:54:28 +0300
Hi,
I am a new user of CGAL and I would like to generate surface meshes with the help of it. But If I understood correctly, we can't generate surface mesh of (for example) a cube with this release. Is it so? If so when do you think the next release will appear?
Thank you in advance
Ahmet Ketenci
Mariette Yvinec wrote:
The generation of surface meshes
for piecewise smooth surfaces, that is with sharp edges,
is not yet in CGAL.
It will be added in the next release to appear in a few months.
M. Hazegh wrote:
I have a set of points in 3D that approximate a surface.
A subset of these points define a set of constraint edges on the surface.
I would like to form a constrained surface mesh. (Something similar to Figure 34.5 of the CGAL manual but in 3D space.)
Can the "3D Surface Mesh Generation" package or other packages in CGAL be used for this?
Regards,
-Ramin Hazegh
