cgal-discuss - [cgal-discuss] connect_holes produces wrong result
  • To: CGAL <>
  • Subject: [cgal-discuss] connect_holes produces wrong result
  • Date: Fri, 29 Aug 2008 14:24:48 -0700
The function connect_holes seems to be failing in certain situations. Specifically, if P is a square, and a diamond shape Q is subtracted from
it, resulting in a square with a diamond hole, then connect_holes returns
a small triangle rather than the expected output.
Below is the output produced by the attached program.
Roger House
Software Developer
A square
[ 4 vertices: (-1 -1) (1 -1) (1 1) (-1 1) ]
P is simple
P is convex
P is counterclockwise
P has area 4
A diamond inside the square P above
[ 4 vertices: (-1 0) (0 -1) (1 0) (0 1) ]
Q is simple
Q is convex
Q is counterclockwise
Q has area 2
Difference P - Q above
{ Outer boundary = [ 8 vertices: (-1 -1) (0 -1) (1 -1) (1 0) (1 1) (0 1) (-1 1) (-1 0) ]
1 holes:
Hole #1 = [ 4 vertices: (1 0) (0 -1) (-1 0) (0 1) ]
Same as above
1 holes:
Number of elements in pointList is 3
Square with diamond hole as a sequence of points
[ 3 vertices: (-1 -1) (0 -1) (-1 0) ]
squareWithNoHoles is simple
squareWithNoHoles is convex
squareWithNoHoles is counterclockwise
squareWithNoHoles has area 0.5
***** connect_holes seems to have a bug *****
// cholebug.cpp -- Demonstration of a bug in the CGAL connect_holes function
#include "CGAL\Cartesian.h"
#include "CGAL\Polygon_2.h"
#include <CGAL\Boolean_set_operations_2.h>
#include <CGAL\Polygon_set_2.h>
#include <CGAL\connect_holes.h>
#include <iostream>
#include <list>
#include <cassert>
using namespace std;
typedef CGAL::Cartesian<double> K;
typedef K::Point_2 Point;
typedef list<Point> Point_list;
typedef CGAL::Polygon_2<K> Polygon_2;
typedef CGAL::Polygon_set_2<K> Polygon_set_2;
typedef CGAL::Polygon_with_holes_2<K> Polygon_with_holes_2;
typedef list<Polygon_with_holes_2> Pwh_list_2;
void print_polygon(const Polygon_2 &poly)
Polygon_2::Vertex_const_iterator vit;
cout << "[ " << poly.size() << " vertices:";
for (vit = poly.vertices_begin(); vit != poly.vertices_end(); ++vit)
cout << " (" << *vit << ')';
cout << " ]" << endl;
void displayPolyInfo(
const Polygon_2 &poly,
const string &name,
const string &desc)
bool isSimple = poly.is_simple();
bool isConvex = poly.is_convex();
bool isCCW = false;
if (isSimple)
isCCW = poly.is_counterclockwise_oriented();
double area = poly.area();
cout << desc << endl;
cout << " ";
print_polygon(poly);
cout << " " << name << " is " << (isSimple ? "" : "not ")
<< "simple" << endl;
cout << " " << name << " is " << (isConvex ? "" : "not ")
<< "convex" << endl;
if (isSimple)
cout << " " << name << " is " << (isCCW
? "counterclockwise" : "clockwise") << endl;
cout << " " << name << " has area " << area << endl;
cout << endl;
void print_polygon_with_holes(const Polygon_with_holes_2 &pwh)
if (!pwh.is_unbounded())
cout << " { Outer boundary = ";
print_polygon (pwh.outer_boundary());
else
cout << " { Unbounded polygon" << endl;
Polygon_with_holes_2::Hole_const_iterator hit;
unsigned int k = 1;
cout << " " << pwh.number_of_holes() << " holes:" << endl;
for (hit = pwh.holes_begin(); hit != pwh.holes_end(); ++hit, ++k)
cout << " Hole #" << k << " = ";
print_polygon(*hit);
cout << " }" << endl;
} // end print_polygon_with_holes
void displayPolyWithHolesInfo(
const Polygon_with_holes_2 &poly,
const string &name,
const string &desc)
print_polygon_with_holes(poly);
cout << endl;
void displayListOfPolyWithHolesInfo(
const Pwh_list_2 &pwh_list,
const string &name,
const string &desc)
Pwh_list_2::const_iterator it;
for (it = pwh_list.begin(); it != pwh_list.end(); ++it)
print_polygon_with_holes(*it);
cout << endl;
int main()
Point pointsP[] = {Point(-1, -1), Point(1, -1), Point(1, 1), Point(-1,
1)};
Polygon_2 P(pointsP, pointsP+4);
displayPolyInfo(P, "P", "A square");
Point pointsQ[] = {Point(-1, 0), Point(0, -1), Point(1, 0), Point(0, 1)};
Polygon_2 Q(pointsQ, pointsQ+4);
displayPolyInfo(Q, "Q", "A diamond inside the square P above");
// Difference P - Q
Pwh_list_2 differencePminusQ;
CGAL::difference(P, Q, back_inserter(differencePminusQ));
displayListOfPolyWithHolesInfo(differencePminusQ, "differencePminusQ",
"Difference P - Q above");
// Now connect holes of the diamond hole to the square outer boundary
Polygon_with_holes_2 squareWithDiamondHole = differencePminusQ.front();
displayPolyWithHolesInfo(squareWithDiamondHole, "squareWithDiamondHole",
"Same as above");
Point_list pointList;
connect_holes(squareWithDiamondHole, back_inserter(pointList));
cout << "Number of elements in pointList is " << pointList.size() << endl;
cout << endl;
Polygon_2 squareWithNoHoles(pointList.begin(), pointList.end());
displayPolyInfo(squareWithNoHoles, "squareWithNoHoles",
"Square with diamond hole as a sequence of points");
cout << "***** connect_holes seems to have a bug *****" << endl;
cout << endl;
cout << "Press any nonwhitespace key and Enter to terminate" << endl;
string c;
cin >> c;
// end cholebug.cpp
  • [cgal-discuss] connect_holes produces wrong result, Roger House, 08/29/2008
