I find your mail a bit rude !
--- On Tue, 9/2/08, Jernej Barbic <> wrote:
From: Jernej Barbic <> Subject: Re: [cgal-discuss] my experience with CGAL To: Date: Tuesday, September 2, 2008, 1:43 PM
Hi Greg,
This should be very easy to do for any person proficient in C++. I looked into Complex_2_in_triangulation_3_file_writer.h and redirected the output to my memory buffer as opposed to an output stream.
As per releasing my code: sorry, I don't have the time to clean my code and release it publicly (I am not a CGAL developer).
Regards, Jernej
On Tue, Sep 2, 2008 at 4:09 PM, Greg Fokum <>
wrote: > hello there > > Saw your correspondence and struggles with CGAL. Could you please share your > code on how you got to obtain the vertices and faces of the triangulation > using Complex_2_in_triangulation_3_file_writer.h as suggested ? > > Regards > > GT > > --- On Tue, 9/2/08, Jernej Barbic <> wrote: > > From: Jernej Barbic <> > Subject: [cgal-discuss] my experience with CGAL > To: > Date: Tuesday, September 2, 2008, 11:11 AM > > Dear CGAL, > > I am posting these two message by invitation of Dr. Pierre Alliez. I > attended the CGAL course at SIGGRAPH in LA, and then tried using CGAL > to do surface mesh generation. I then had an email discussion > with > Pierre, relating my experience with CGAL. Also, please note that
(due > to other work) it might be difficult for me to keep up with the > follow-ups; however, I wanted to share my experience, so I wrote the > emails below. Best of luck to CGAL! > > Regards, > Jernej Barbic > Post-doc associate, Computer Science and Artificial Intelligence Lab, > Massachusetts Institute of Technology > http://people.csail.mit.edu/barbic/ > > The first email message: > =================== > > Dear Pierre, > > I am a computer graphics post-doc at MIT, and I saw your presentation > in this year's SIGGRAPH class on CGAL in Los Angeles. > > I was impressed with the presentation and the capabilities of CGAL, so > I tried using it as a tool in my project. Specifically, I wanted to > use it to generate good quality triangulations of isosurfaces, as in > the "skull" >
example: > http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher/Chapter_main.html > > I managed to compile and run the "skull" example (under Mac OS X). > However, I then ran into a problem which will most likely seem quite > trivial to you: I was unable to adapt the example so that I could > actually capture the output. That is, CGAL will generate an output > mesh; I then wanted to convert this mesh to my own in-memory > representation. This representation would be very simple: a list of > vertices, each given as three double precision values, followed by a > list of faces (triangles), each a set of three integer indices into > the preceding table of vertices. I was ultimately unable to figure out > how to do this. > > I listened to your presentation at SIGGRAPH, and then read the CGAL > manual several times. I spent two days looking through
many CGAL > header files (about 8-10 hours of work total), following > seemingly > endless templated (and cryptic at times) arguments, in an attempt to > find clues as per how to access vertices of triangulations, and how to > obtain the integer indices of the vertices of every face. For example, > I "chased" the definition of "Vertex", over many header > files, > following (many) typedefs and templates, and did not succeed in > finding a final answer. > > I program in C++ all the time, and am quite proficient with templates > and STL. I could not find a final answer - and got a bit frustrated > given how simple and trivial the task. If I was on the CGAL team, I am > pretty sure I could just ask somebody and get the answer very quickly, > but with the information available to me, things were difficult. > > Here is what I did figure out. One can
print out the vertices like this: > > for ( C2t3::Vertex_iterator v = c2t3.vertices_begin(); v != > c2t3.vertices_end(); ++v) > { > std::cout << "v > " << v->point() << > std::endl; > } > > (but printing is not what I really wanted; it would be better if I > could store v->point() into a C array such as "double [3]") > > And one can traverse the faces (but unsure if these are tet mesh > cells, or surface mesh triangles, or surface mesh > triangles+edges+vertices) like this: > > int count = 0; > for(C2t3::Facet_iterator f = c2t3.facets_begin(); f != c2t3.facets_end(); > f++) > { > //printf("%d\n", f->second); // this I am guessing is the > dimensionality of the facet > if (f->second == 3) > { > std::cout << f->first->vertex(0)->point()
<< " > "; > std::cout << f->first->vertex(1)->point() << " > "; > std::cout << f->first->vertex(2)->point(); > std::cout << std::endl; > count++; > } > } > > However, here I don't know what to do with > f->first->vertex to pull > out the global integer index of that vertex. As you can see, I figured > out how to convert the vertex to its 3D location (3 coordinates); but > getting the global integer index would be much better. Also, I am not > sure if this method will give me the triangle faces of the surface > mesh, or will it give me the entire tet mesh. And if I run it on the > (unmodified, as shipped with CGAL) skull example, I get many 4-tuples > (I assume tets from the output tetrahedralization) that look ok, but > at the end there are several that have
three zero entries and one > entry equalling 1. So if those are tets, unsure what they mean. > > I think CGAL is great: it really implements many useful algorithms and > the ability to have exact arithmetic is very good. Based on my > experience, may I add a suggestion: right now, the manual talks a lot > about templates and about computational geometry algorithms, which > is > all good. Templates certainly make CGAL more powerful. However, at > times the manual reads like the art of templatization was the main > point of CGAL; there is a lot of template lingo. This will be good for > somebody who is much into templates, but might be difficult to read > for other people. I would add even more concrete examples: whenever > you present some generic datastructure or algorithm (such as the > kernel, for example), consider giving concrete examples of templated >
arguments that one can pass to those datastructures or algorithms. And > as per triangulations, it would be good to have a manual page listing > the methods available to vertex iterators, face iterators, cell > iterators; the difference between face, facet, cell; and more > documentation on input and output. > > Thank you for creating CGAL, and for your help, > Jernej Barbic > > The second email message: > ====================== > >>>dear > Jernej, >>> >>>thanks for your positive feedback, that's very useful and > encouraging. >>> >>>as I am still on holidays, the short answer can be found in file > Complex_2_in_triangulation_3_file_writer.h >>> >>>I invite you to post your detailed email to the CGAL discuss list, so > that all developers see the trend (more and more people
start using that > surface > mesh generator, that's good to know). >>> >>>thanks again for your time, >>> >>>Pierre > > Hi Pierre, > > Thank you very much for the pointer to > Complex_2_in_triangulation_3_file_writer.h. I was able to > "reverse-engineer" that file and now the mesher works fine for me. I > already meshed several isosurfaces. The mesher is very good. I am not > aware of any other mesher that can achieve similar results. > > One minor issue that I noticed is that there is sometimes a spot on > the output mesh > where for some reason the vertex density is > unnecessarily high. If there is such a spot, there is always exactly > one. It's not a big deal, but it does require either removing it > manually, or running several runs, guessing parameters until it > disappears. The location
of this spot might be related to the location > of the center of the bounding sphere (user-supplied parameter), and to > how deep that center is inside the volume enclosed by the isosurface. > But not 100% sure. > > Also, documentation says that the sphere center must be inside the > volume enclosed by the isosurface - but I noticed that the mesher > produces a plausible result even if it is not. And, I am not > completely sure if the bounding sphere has to cover the entire volume > where the grayscale image is defined, or only the output isosurface. > Also, I don't exactly understand the difference between the "distance > bound" and "radius bound" (inputs to the > mesher); I read it > several > times in the manual and from that text I don't see the difference (and > I know they must be different, or else you would not have two separate >
parameters). > > FYI: I am combining your surface mesher with "tetgen" to generate > volumetric tet meshes (I do so since I am assuming that your mesher > doesn't generate a (quality) tet mesh, only a quality surface mesh). I > am getting very good quality meshes using this process. > > Again, my suggestion to CGAL would be to boost the documentation. Much > of the documentation talks about "concepts" and how these concepts > are > implemented in "models". This is interesting on its own, however, it > might be hard for a CGAL novice to parse this. For example, I'd try to > lookup "Vertex", expecting to see a concrete class, and a list of > methods that can be used with this class. Instead, there would be lots > of typedefs and talk about how this is a model of > some concept and how > it has to implement certain things. And then I'd wonder why
those > typedefs are the way they are, and what alternative choices would be > and where I would look up those. And whether the class that I am > looking at (Vertex) is an actual class that I can use, or is it just > an abstract concept for me to implement (or partially implement), etc. > All this is just my 5 cents of course, take my criticism lightly. I > realize templatization has big benefits. > > As per posting to the CGAL discussion list, please go ahead and post > my previous email, in my name (it is easier for me if you post it, > than if I post it). You can also post this email if you wish. > > Thank you for your help. > Jernej Barbic > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > > -- You are currently subscribed to
cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss
