- To:
- Subject: Re: [cgal-discuss] Hole vertex on outer boundary blows up join
- Date: Thu, 11 Sep 2008 12:53:14 +0300
Polygon_set_2 has a member function is_valid(). We are working on
providing well defined and documented means to test the validity of
polygons and polygons with holes.
There are some undocumented functions that do that (take a look at
/Boolean_set_operations_2/Gps_polygon_validation.h), but their API is
likely to change.
Roger House wrote:
> Thank you very much for this information. I added vertex (2,4) to the
> top edge of the square,
> and, indeed, everything worked fine.
> Is there a Polygon_with_holes_2 function that I can call to check if
> a polygon is well-formed?
> I have not seen one in the User and Reference Manual, and when I look
> at the source code I
> quickly become confused. Despite the detail and length of the manual,
> it seems that there are
> very useful functions which it doesn't mention and which I am unable
> to determine how to use.
> Any help will be appreciated.
> Roger House
> Efraim Fogel wrote:
>> This is not a bug. The polygon with holes you generate is invalid.
>> If you want to generate a valid polygon with holes with identical
>> geometry, in this case you must compute the difference between the
>> polygon outer boundary and the hole.
>> It is not completely your fault though. The function add_hole() has a
>> precondition below, which is currently missing from the documentation,
>> or at least vague. The code you attach violates the precondition.
>> The boundary of a hole and the outer boundary of the polygon with holes
>> must not cross. Moreover, they must not intersect, except for at
>> vertices.
>> If you add the vertex (2,4) to the outer boundary, everything works
>> fine.
>> Roger House wrote:
>>> CGAL seems to have trouble with a polygon which has a hole with a
>>> vertex
>>> of the hole on the outer boundary of the polygon.
>>> Specifically, if G is a square with a triangular hole with the top
>>> vertex
>>> of the triangle on the top edge of the hole, and R is a rectangle
>>> inside
>>> the square, disjoint from the square and the hole, then join(G,R) blows
>>> up. If the top vertex of the triangle is moved slightly inside the
>>> square,
>>> everything works fine.
>>> Below is the output produced by the attached test program.
>>> By the way, using CGAL::Exact_predicates_exact_constructions_kernel
>>> still
>>> resulted in a blow up.
>>> Roger House
>>> Software Developer
>>> The following was sent to stderr by CGAL
>>> CGAL warning: check violation!
>>> Expr: is_simple
>>> File:
>>> c:\users\roghouse\332\build\projects\cgal_eesof\include\cgal\boolean_set_operations_2\gps_polygon_validation.h
>>> Line: 190
>>> Explanation:The polygon is not simple.
>>> CGAL error: precondition violation!
>>> Expr: m_traits->is_valid_2_object()(pgn_with_holes)
>>> File:
>>> c:\users\roghouse\332\build\projects\cgal_eesof\include\cgal\general_polygon_set_2.h
>>> Line: 207
>>> Explanation:
>>> The following was sent to stdout by edgehole.cpp
>>> Top vertex of triangle hole is inside square: Works
>>> Square with triangle hole
>>> { Outer boundary =
>>> [ 4 vertices: (0 0) (4 0) (4 4) (0 4) ]
>>> is simple
>>> is convex
>>> is counterclockwise
>>> has area 16
>>> 1 holes:
>>> Hole #1 =
>>> [ 3 vertices: (2 3.9) (3 3) (1 3) ]
>>> is simple
>>> is convex
>>> is clockwise
>>> has area -0.9
>>> Rectangle inside G square
>>> { Outer boundary =
>>> [ 4 vertices: (1 1) (3 1) (3 2) (1 2) ]
>>> is simple
>>> is convex
>>> is counterclockwise
>>> has area 2
>>> 0 holes:
>>> Union of G and R
>>> { Outer boundary =
>>> is simple
>>> is convex
>>> is counterclockwise
>>> has area 16
>>> 1 holes:
>>> Hole #1 =
>>> [ 3 vertices: (3 3) (1 3) (2 3.9) ]
>>> is simple
>>> is convex
>>> is clockwise
>>> has area -0.9
>>> Top vertex of triangle hole is on square edge: Blows up
>>> { Outer boundary =
>>> is simple
>>> is convex
>>> is counterclockwise
>>> has area 16
>>> 1 holes:
>>> Hole #1 =
>>> [ 3 vertices: (2 4) (3 3) (1 3) ]
>>> is simple
>>> is convex
>>> is clockwise
>>> has area -1
>>> { Outer boundary =
>>> is simple
>>> is convex
>>> is counterclockwise
>>> has area 2
>>> 0 holes:
>>> EXCEPTION THROWN!
>>> CGAL ERROR: precondition violation!
>>> File:
>>> Line: 207
>>> Press any nonwhitespace key and Enter to terminate
>>> // edgehole.cpp -- Demonstration of bug in CGAL: Hole vertex on
>>> outer
>>> // boundary of polygon causes blow up
>>> #include "CGAL\Cartesian.h"
>>> #include "CGAL\Polygon_2.h"
>>> #include <CGAL\Boolean_set_operations_2.h>
>>> #include <CGAL\Polygon_set_2.h>
>>> #include <CGAL\connect_holes.h>
>>> #include <iostream>
>>> #include <list>
>>> #include <cassert>
>>> using namespace std;
>>> typedef CGAL::Cartesian<double> K;
>>> typedef K::Point_2 Point;
>>> typedef list<Point> Point_list;
>>> typedef CGAL::Polygon_2<K> Polygon_2;
>>> typedef CGAL::Polygon_set_2<K> Polygon_set_2;
>>> typedef CGAL::Polygon_with_holes_2<K> Polygon_with_holes_2;
>>> typedef list<Polygon_with_holes_2> Pwh_list_2;
>>> void print_polygon(const Polygon_2 &poly)
>>> Polygon_2::Vertex_const_iterator vit;
>>> cout << "[ " << poly.size() << " vertices:";
>>> for (vit = poly.vertices_begin(); vit != poly.vertices_end();
>>> ++vit)
>>> cout << " (" << *vit << ')';
>>> cout << " ]" << endl;
>>> void print_polygon_info(const Polygon_2 &poly, const string &name,
>>> const string &desc)
>>> bool isSimple = poly.is_simple();
>>> bool isConvex = poly.is_convex();
>>> bool isCCW = false;
>>> if (isSimple)
>>> isCCW = poly.is_counterclockwise_oriented();
>>> double area = poly.area();
>>> cout << desc << endl;
>>> cout << " ";
>>> print_polygon(poly);
>>> cout << " " << name << " is " << (isSimple ? "" : "not ") <<
>>> "simple" << endl;
>>> cout << " " << name << " is " << (isConvex ? "" : "not ") <<
>>> "convex" << endl;
>>> if (isSimple)
>>> cout << " " << name << " is " << (isCCW ? "counterclockwise"
>>> : "clockwise") << endl;
>>> cout << " " << name << " has area " << area << endl;
>>> cout << endl;
>>> void print_polygon_with_holes(const Polygon_with_holes_2 &pwh)
>>> if (!pwh.is_unbounded())
>>> // cout << " { Outer boundary = ";
>>> cout << " { ";
>>> print_polygon_info (pwh.outer_boundary(), "", "Outer
>>> boundary = ");
>>> else
>>> cout << " { Unbounded polygon" << endl;
>>> Polygon_with_holes_2::Hole_const_iterator hit;
>>> unsigned int k = 1;
>>> cout << " " << pwh.number_of_holes() << " holes:" << endl;
>>> for (hit = pwh.holes_begin(); hit != pwh.holes_end(); ++hit, ++k)
>>> cout << " Hole #" << k << " = ";
>>> print_polygon_info(*hit, "", "");
>>> cout << " }" << endl;
>>> } // end print_polygon_with_holes
>>> void print_polygon_with_holes_info(const Polygon_with_holes_2 &poly,
>>> const string &name, const string &desc)
>>> print_polygon_with_holes(poly);
>>> cout << endl;
>>> void print_list_of_polygons_with_holes_info(const Pwh_list_2
>>> &pwh_list, const string &name, const string &desc)
>>> Pwh_list_2::const_iterator it;
>>> for (it = pwh_list.begin(); it != pwh_list.end(); ++it)
>>> print_polygon_with_holes(*it);
>>> if ( pwh_list.begin() == pwh_list.end())
>>> cout << " the list of polygons with holes is empty" << endl;
>>> cout << endl;
>>> void show_bug(Point &top_of_triangle)
>>> Polygon_with_holes_2 G;
>>> G.outer_boundary().push_back( Point(0, 0) );
>>> G.outer_boundary().push_back( Point(4, 0) );
>>> G.outer_boundary().push_back( Point(4, 4) );
>>> G.outer_boundary().push_back( Point(0, 4) );
>>> Polygon_2 holeG;
>>> holeG.push_back( top_of_triangle );
>>> holeG.push_back( Point(3, 3) );
>>> holeG.push_back( Point(1, 3) );
>>> G.add_hole(holeG);
>>> Polygon_with_holes_2 R;
>>> R.outer_boundary().push_back( Point(1, 1) );
>>> R.outer_boundary().push_back( Point(3, 1) );
>>> R.outer_boundary().push_back( Point(3, 2) );
>>> R.outer_boundary().push_back( Point(1, 2) );
>>> print_polygon_with_holes_info(G, "G", "Square with triangle hole");
>>> print_polygon_with_holes_info(R, "R", "Rectangle inside G square");
>>> Polygon_with_holes_2 unionGandR;
>>> bool disjoint = !CGAL::join(G, R, unionGandR);
>>> assert(!disjoint);
>>> print_polygon_with_holes_info(unionGandR, "unionGandR", "Union
>>> of G and R");
>>> } // end show_bug
>>> int main()
>>> try
>>> { cout << "Top vertex of triangle hole is inside
>>> square: Works" << endl;
>>> show_bug( Point(2, 3.9) ); // This will work
>>> cout << "Top vertex of triangle hole is on square edge:
>>> Blows up" << endl;
>>> show_bug( Point(2, 4 ) ); // This blows up
>>> catch (exception& e)
>>> cout << "EXCEPTION THROWN!" << endl;
>>> cout << e.what() << endl;
>>> cout << "Press any nonwhitespace key and Enter to terminate" <<
>>> endl;
>>> string c;
>>> cin >> c;
>>> } // end main
>>> // end edgehole.cpp
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] Hole vertex on outer boundary blows up join, Roger House, 09/06/2008
- Re: [cgal-discuss] Hole vertex on outer boundary blows up join, Efraim Fogel, 09/09/2008
- Re: [cgal-discuss] Hole vertex on outer boundary blows up join, Roger House, 09/10/2008
- Re: [cgal-discuss] Hole vertex on outer boundary blows up join, Efraim Fogel, 09/11/2008
- [cgal-discuss] segment delaunay graph, jiatao83, 09/10/2008
