- To:
- Subject: [cgal-discuss] missing libGL.dylib
- Date: Mon, 22 Sep 2008 19:56:10 +0200 (CEST)
Hello all,
I've been able to compile the CGAL libraries a linux Cluster.
Now I'm trying to compile a program that uses CGAL.
When compiling I get this error
/usr/bin/g++ -o wv wv.o
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
'-L/work/00981/pederzan/CGAL-3.3.1/lib/x86-64_Linux-2.6_g++-3.4.6'
-L/usr/X11R6/lib64
-Wl,-R/work/00981/pederzan/CGAL-3.3.1/lib/x86-64_Linux-2.6_g++-3.4.6:/usr/X11R6/lib64
-lCGAL -lCGALimageIO -lCGALPDB -lGL -lGLU -lz -lX11 -lm
/opt/apps/binutils/binutils-2.17/bin/ld:
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:
No such file: No such file or directory
collect2: ld returned 1 exit status
gmake: *** [wv] Error 1
Is this a problem with how I compiled the CGAL libraries or with the program
that uses the CGAL libraries?
Thank you for your help
Jean-Noel Pederzani
- [cgal-discuss] missing libGL.dylib, pederzani, 09/22/2008
