- To:
- Subject: Re: [cgal-discuss] How to remesh the surface of object described
- Date: Tue, 23 Sep 2008 18:21:14 +0200
- Organization: INRIA
hi Samay,
as soon as you can quickly intersect a triangle surface mesh with a 3D ray, line or segment you can remesh it using the current surface meshing of CGAL. such efficient intersection routines are not yet in CGAL but we are working on it.
Samay Kumar a écrit :
Hello Friends,
Can anyone help me how to re-mesh the surface of object described in .off file?
Actually I want to analyze local geometric properties (e.g., surface normal, distance between two points over surface) of object surface and I think re-meshing the surface will allow me to analyze more polygonal facets.
Greetings,
Samay
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- [cgal-discuss] How to remesh the surface of object described by .off ?, Samay Kumar, 09/23/2008
- Re: [cgal-discuss] How to remesh the surface of object described, Pierre Alliez, 09/23/2008
