- To:
- Subject: [cgal-discuss] 3d surface mesher non deterministic
- Date: Wed, 24 Sep 2008 15:30:52 +0200 (CEST)
hi,
I tried to run CGAL/examples/Surface_mesher/mesh_an_implicit_function.cpp and
noticed that each time I run the program, the output is
slightly different.
The resulting mesh approximating the given geometry, in fact, has different
points and cells.
Why is this process not deterministic? Is there a way to make it
deterministic?
greetings
- [cgal-discuss] 3d surface mesher non deterministic, dassifraa, 09/24/2008
- Re: [cgal-discuss] 3d surface mesher non deterministic, Laurent Rineau, 09/24/2008
- Re: Re: [cgal-discuss] 3d surface mesher non deterministic, dassifraa, 09/24/2008
- RE: [cgal-discuss] 3d surface mesher non deterministic, HAQUE, AKTER_HASNINE (GE Healthcare), 09/25/2008
- Re: [cgal-discuss] 3d surface mesher non deterministic, Laurent Rineau, 09/25/2008
