- To:
- Subject: [cgal-discuss] About Polyhedron in Subdivision
- Date: Sun, 28 Sep 2008 16:17:36 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=USAvZxAqcZHwOrSM1ICcKz6yeHKTdTioxiqH/bZO70xek+fVrcY+9WKBXM7W1m1moG Fm0gWwyq4c84QSxmblliWLCG741zKmQAM4rDh6kCQU6uJI08u2G8X+4eG71nl9aGqRT7 T4vh2nQ4w3FugNAXoCp9DHkiTFFGAx4+ay+Tc=
Dear all:
When I use the sqrt3_subdivision method(Polyhedron, step), the function make_triangle(p1, p2, p3) is used
to creat a new polyhedron (Do I must use the *.off file ?)
After the sqrt3_subdivision is excuted, I got each facet using facet iterator. The output result is wrong, for
example, the total number of facets is 57, but some of this facets just like a line (two points is very close).
I don't know where is the problem. Can anyone halps me, thanks very much.
The attech file is the output of my result.
Description: JPEG image
- [cgal-discuss] About Polyhedron in Subdivision, BJStation BJ, 09/28/2008
