- To:
- Subject: [cgal-discuss] kernel of a polygon
- Date: Mon, 29 Sep 2008 14:41:27 +0200
- Organization: INRIA
hi all,
inspired by http://www.qhull.org/html/qhalf.htm
(see qhalf notes)
I am using the QP solver (used as LP solver) to compute the kernel of a polyon in 2D. as I obtain strange results - I would appreciate if someone with experience on the QP solve could take a look at the following code. the input is a set of 2D segments.
// LP solver to compute polygon kernels
#include <CGAL/QP_functions.h>
#include <CGAL/QP_models.h>
template <class Kernel, class ET>
class CPolygon_kernel
private:
// basic types
typedef typename Kernel::FT FT;
typedef typename Kernel::Line_2 Line;
typedef typename Kernel::Point_2 Point;
typedef typename Kernel::Vector_2 Vector;
typedef typename Kernel::Segment_2 Segment;
// program and solution types
typedef CGAL::Quadratic_program<double> LP;
typedef typename CGAL::Quadratic_program_solution<typename ET> Solution;
typedef typename Solution::Variable_value_iterator Variable_value_iterator;
Solution m_solution;
Point m_inside_point;
typedef CGAL::Real_embeddable_traits<typename Variable_value_iterator::value_type> RE_traits;
typename RE_traits::To_double to_double;
public:
CPolygon_kernel() {}
~CPolygon_kernel() {}
public:
Point& inside_point() { return m_inside_point; }
const Point& inside_point() const { return m_inside_point; }
unsigned int number_of_iterations() { return m_solution.number_of_iterations(); }
public:
// assume polygon given per segment and CCW
template < class InputIterator >
bool solve(InputIterator begin, InputIterator end)
// solve linear program
LP lp(CGAL::LARGER); // with constraints Ax >= b
// column indices
const int index_x1 = 0;
const int index_x2 = 1;
const int index_x3 = 2;
// assemble linear program
int j = 0; // row index
InputIterator it;
for(it = begin; it != end; it++,j++) // iterate over segments
const Segment& segment = *it;
const Point a = segment.source();
const Point b = segment.target();
Vector ab = b - a;
Vector normal = unit_normal(ab); // CW 90 deg rotation
const FT aj = normal.x();
const FT bj = normal.y();
// constraint (line j): aj * x1 + bj * x2 - x3 >= -cj
lp.set_a(index_x1, j, aj);
lp.set_a(index_x2, j, bj);
lp.set_a(index_x3, j, -1.0);
// right hand side
Line line(a,b);
FT c = to_double(line.c());
FT cj = distance_to_origin(line) * CGAL::sign(c);
lp.set_b(j, -cj);
// or equivalently...
// Line line(a,normalize(ab));
// FT cj = to_double(line.c());
// lp.set_b(j, -cj);
// objective function -> max x3 (negative sign set because
// the lp solver always minimizes an objective function)
lp.set_c(index_x3,-1.0);
// add constraints over x3 (>= 0). somewhat redundant
// constraint as we later test for x3 > 0
lp.set_l(index_x3,true,0.0);
// solve the linear program
m_solution = CGAL::solve_linear_program(lp, ET());
if(m_solution.is_infeasible())
return false;
if(!m_solution.is_optimal())
return false;
// get variables
Variable_value_iterator X = m_solution.variable_values_begin();
// solution if x3 > 0
double x3 = to_double(X[2]);
if(x3 <= 0.0)
return false;
// define inside point as (x1;x2)
double x1 = to_double(X[0]);
double x2 = to_double(X[1]);
m_inside_point = Point(x1,x2);
return true;
Vector normalize(Vector v)
return v / std::sqrt(v*v);
Vector unit_normal(const Vector& v)
Vector normal(v.y(),-v.x()); // 90 deg CW rotation
return normalize(normal);
FT distance_to_origin(const Line& line)
return std::sqrt(CGAL::squared_distance(Point(CGAL::ORIGIN),line));
- [cgal-discuss] kernel of a polygon, Pierre Alliez, 09/29/2008
