- To:
- Subject: Re: [cgal-discuss] Arrangement vertex DCEL extra data gets lost
- Date: Tue, 30 Sep 2008 13:21:50 +0300
Actually, in athis small testing code (at first, two rays originating from the
same location, and then overrunning the vertex with a line through it), the
data was kept alright. I will try to find out what's wrong with my (bigger)
code.
Thanks,
Amir.
Quoting
> Quoting
> > Hello everyone,
> > I've noticed that in an arrangement, in which some vertices contain data,
> and
> > to which a curve is added that passes through this vertex, the data
> > is deleted
> > - I reckon that the vertex is replaced somehow. I do not know in
> > advance which
> > vertex would it be. What is the best method to preserve the data of
> > the vertex?
> This doesn't sound right. Could you please provide a small program
> that reproduces it? Thanks.
> > Amir.
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Arrangement vertex DCEL extra data gets lost, avaxman, 09/29/2008
- Re: [cgal-discuss] Arrangement vertex DCEL extra data gets lost, efif, 09/30/2008
- Re: [cgal-discuss] Arrangement vertex DCEL extra data gets lost, avaxman, 09/30/2008
