cgal-discuss - Re: [cgal-discuss] Polygon_2::bbox won't compile
  • To:
  • Subject: Re: [cgal-discuss] Polygon_2::bbox won't compile
  • Date: Tue, 30 Sep 2008 17:35:12 +0200
  • Organization: INRIA
Roger House wrote:
I encountered a problem with Polygon_2::bbox which I believe I have fixed, but I would like confirmation. Unfortunately, I have not been able to devise a small program which demonstrates the problem, and I am unable to send the larger program in which the problem arose. However, the context was this:
static bool some_func(const CGAL_Polygon &poly)
CGAL_Bbox bbox = poly.bbox();
The call of poly.bbox resulted in the error message at the end of this email, in which line 234 of Polygon_2.h is mentioned. The return statement in the following function is line 234 of Polygon_2.h:
Bbox_2 bbox() const
return bbox_2(d_container.begin(), d_container.end());
After looking at some of the nearby code in Polygon_2.h, I made a wild guess and added a third parameter:
return bbox_2(d_container.begin(), d_container.end(), traits);
This not only compiled, but it seems to be working.
Please let me if this fix is okay.
Well, no, the code is supposed to be correct.
I can't think of a reason why you see what you see.
Please provide more context if possible.
Thank you,
Roger House
/usr/include/CGAL/Polygon_2.h: In member function ‘CGAL::Bbox_2 CGAL::Polygon_2<Traits_, Container_>::bbox() const [with Traits_P = CGAL::Cartesian<double>, Container_P = std::vector<CGAL::Point_2<CGAL::Cartesian<double> >, std::allocator<CGAL::Point_2<CGAL::Cartesian<double> > > >]’:
connhole.cpp:320: instantiated from here
/usr/include/CGAL/Polygon_2.h:234: error: no matching function for call to ‘bbox_2(__gnu_cxx::__normal_iterator<const CGAL::Point_2<CGAL::Cartesian<double> >*, std::vector<CGAL::Point_2<CGAL::Cartesian<double> >, std::allocator<CGAL::Point_2<CGAL::Cartesian<double> > > > >, __gnu_cxx::__normal_iterator<const CGAL::Point_2<CGAL::Cartesian<double> >*, std::vector<CGAL::Point_2<CGAL::Cartesian<double> >, std::allocator<CGAL::Point_2<CGAL::Cartesian<double> > > > >)’
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
