- To:
- Subject: Re: [cgal-discuss] Need help with Boolean Operation
- Date: Wed, 01 Oct 2008 17:34:54 +0200
- Organization: INRIA
hi Samay,
what you can do is to take two polyhedral triangular surfaces (without boundaries, non self-intersecting), convert them as Nef_polyhedra, apply the Boolean operation, and convert back the result to a polyhedral surface (if feasible).
Pierre
Samay Kumar a écrit :
Hello Friends,
I want to do boolean operation of polyhedral surface and solid cylinder.
I have attached one .jpg file in which operation is shown in more detail. I want to acquire set of polygonal facets (in figure colored with RED) of polyhedral object as result of boolean operation between polyhedral surface and solid cylinder.
May any one give advice how to proceed with CGAL?
Thanks.
Greetings,
Samaay
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- [cgal-discuss] Need help with Boolean Operation, Samay Kumar, 10/01/2008
- Re: [cgal-discuss] Need help with Boolean Operation, Pierre Alliez, 10/01/2008
